Thank you for the quick and helpful response. It is exactly what I needed.
I created a WebCoRE account. I have tried to register the e9ohw code, however, the page only accepts the first 4 characters.
I’m just learning the SmartThings/WebCoRE environment so I ask for you patience. The WebCoRE IDE seems like it will be a very powerful development environment.
Here is the instructions for installing webcore.
The import code is for importing the piston I made for you.
It sounds like you are trying to use it to register a browser.
I tried that path and got to the 3rd step where it say to click in Setting but I don’t see a Settings tab. Do I need to Enable GitHub Integration first in order to get the Setting Tab?
Enabled the GritHub and have the 4 code blocks loaded (WebCoRE, Dashboard, Piston, Storage), however, I must have missed clicking the Publish checkbox before clicking Execute Update. Now I have all four blocks installed but the installation is not complete.
Have you followed the instructions to enable OAuth for the app. And then followed the rest of the instructions below it to install the smart app and authorise all your devices you wish to use with webcore?
Follow. 4.3 then 4.4 then 4.5 and 4.6 of the wiki
Click this link below to get to the rest of the installation instructions.
Thanks to your help I have the WebCoRE Dashboard up. Tomorrow I will try to import your code and then add to it from there. I am looking forward to using the development environment.
I am trying to register my browser so I can access the WebCoRE Dashboard on my PC.
I got the 3 minute duration code from my iPad, entered it, along with my webcore login information. Then a screen comes up asking to authenticate using Home/webcore password. I reentered the webcore password, which I know to be correct but it is not accepted?
Excellent. You’re almost there. Just to confirm, on your iPad if you go to the smartthings app.
Once loaded. Click on the middle icon at the bottom “Automation” then the rightmost tab “smartapp” then select “webcore” then register a browser.
This will give you your browser registration code.
Then navigate to the address shown. Once there you will input the code you have just been given.
Next is the password screen. This is the password you set up in the settings of webcore. If it’s not working for you and you are sure it is correct. Just try changing it in the settings.
Even when the options menu is selected it doesn’t show the WAIT construct as a possible selection. I looked in the wiki and it was show as crossed of the to-do list and you used it.
