Anyone using Qubino 1D Relay (ZMNHND1) UK
I have successfully connected this my ST hub and operate it to the point of being on or off, however I need it to operate a garage door opener and for this it needs to simulate a momentary switch. This is possible with the Qubino but I need to change a parameter and that’s what I can’t do.
I believe I can do this by setting up a device handler which I’ve tried but with no luck so I’m obviously doing something wrong.
Please can someone help? Here’s a guide from the vendor, explaining very well that I need to change parameter 11 to 1;
http://www.vesternet.com/downloads/dl/file/id/1137/product/1477/z_wave_qubino_flush_1d_relay_plus_user_manual_v1_2.pdf1
and here’s the full manual;
If it helps here is the script I used in my device handler, all I did was add the parameter bit at the bottom, device still works but parameter doesn’t kick in as on button stays on;
  • Copyright 2015 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Z-Wave Relay", namespace: "smartthings", author: "SmartThings") {
	capability "Actuator"
	capability "Switch"
	capability "Polling"
	capability "Refresh"
	capability "Sensor"
	capability "Relay Switch"
	fingerprint deviceId: "0x1001", inClusters: "0x20,0x25,0x27,0x72,0x86,0x70,0x85"
	fingerprint deviceId: "0x1003", inClusters: "0x25,0x2B,0x2C,0x27,0x75,0x73,0x70,0x86,0x72"
// simulator metadata
simulator {
	status "on":  "command: 2003, payload: FF"
	status "off": "command: 2003, payload: 00"
	// reply messages
	reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
	reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
	standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
		state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
		state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
	standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
		state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
	main "switch"
	details(["switch","refresh"])
def installed() {
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x70: 1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result?.name == ‘hail’ && hubFirmwareLessThan(“000.011.00602”)) {
result = [result, response(zwave.basicV1.basicGet())]
log.debug “Was hailed: requesting state update”
} else {
log.debug “Parse returned ${result?.descriptionText}”
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: “switch”, value: cmd.value ? “on” : “off”, type: “physical”]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: “switch”, value: cmd.value ? “on” : “off”, type: “digital”]
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
def value = "when off"
if (cmd.configurationValue[0] == 1) {value = “when on”}
if (cmd.configurationValue[0] == 2) {value = “never”}
[name: “indicatorStatus”, value: value, display: false]
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
[name: “hail”, value: “hail”, descriptionText: “Switch button was pressed”, displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue(“manufacturer”, cmd.manufacturerName)
final relays = [
    [manufacturerId:0x0113, productTypeId: 0x5246, productId: 0x3133, productName: "Evolve LFM-20"],
    [manufacturerId:0x0113, productTypeId: 0x5246, productId: 0x3133, productName: "Linear FS20Z-1"],
	[manufacturerId:0x5254, productTypeId: 0x8000, productId: 0x0002, productName: "Remotec ZFM-80"]
def productName  = null
for (it in relays) {
	if (it.manufacturerId == cmd.manufacturerId && it.productTypeId == cmd.productTypeId && it.productId == cmd.productId) {
		productName = it.productName
		break
if (productName) {
	log.debug "Relay found: $productName"
	updateDataValue("productName", productName)
else {
	log.debug "Not a relay, retyping to Z-Wave Switch"
	setDeviceType("Z-Wave Switch")
[name: "manufacturer", value: cmd.manufacturerName]
// Handles all Z-Wave commands we aren’t interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
def refresh() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
def updated() {
response([zwave.configurationV1.configurationSet(parameterNumber: 11, size: 1, scaledConfigurationValue: 1).format()])
