I have a ~2017 Samsung 32" and am using a Roku stick to stream shows.
Scenario: I am trying to use a motion sensor to turn on the TV when motion is detected without using IR blasters and line of sight will be difficult as the TV is on an articulating arm.
I tried a ST plug to turn it on. It worked if the TV was previously on within the last few minutes. Otherwise if the TV had been off for a while, it couldn’t wake it up and turn it on.
How do you wake up a TV without Has anyone been successful doing this and would be willing to explain how you got this to work?
If your remote can turn on the TV just by pressing the home button, then the next thing to try is to send a Wake On LAN command to the Roku while it is dormant. If that turns it on and the attached TV turns on as well, then you can work to automate a Wake On LAN from Smartthings. This would give you options to have a sensor kick off the automation.
Not all devices are compatible with the Wake On LAN, so you’ll have to experiment.
In the smartthings app, i can use the virtual remote control to turn the TV on (even though the cloud symbol says it’s offline). When switching ON, i do get some kind of error message about TV being offline, but it still switches on.
However, in the automation there’s only “OFF” -option.
Any ideas how to get this work? My goal is to make a routine to start the TV every morning, and switch to a specific channel.
I just find it weird, and a bit funny, that I can do all the things needed with the virtual remote control on smartthings app, but i can’t set automations to perform those same things. Maybe i’ll get Raspberry Pi and start working through that
I also have Chromecast and Google Home in use, if those are of any help.
Here is what I did. I have a ST motion sensor + a ST wall outlet set up to turn on my Samsung TV when I come into the room. I turned on the TV via the remote initially and it has turned on/off automatically ever since using the ST motion sensor and outlet.
You could probably do the same thing without the motion sensor just using a timed tasking in the ST app. However, you would have to buy a ST hub to make all this work.
