Looks like you’ve got “light between the switches #2” configuration.
Just an aside: the Zooz ZEN26 switch and ZEN27 dimmer let you smarten a 3-way by only replacing one side. The other side retains the dumb switch and does not need to be required. If you’re doing a dimmer, you don’t gain the ability to dim from both switches, the dumb side remains on/off only. And there are some load limits that need to be watched. But it’s a significant cost savings.
