Annoying bug in the iOS app around setting a time in automations
While editing the ‘Smart Lighting’ automation with the app there’s an anoying bug when setting a ‘Start time’ and ‘End Time’ where it doesnt allow you to set a time as it refreshes itself before you can set the correct time.
I’m on an iPhone 11 running the latest iOS 13.1.2.
I can confirm this. I too am experiencing this problem. I’m experiencing the problem on my iPad Air 2 iOS 12
I am able to reproduce this issue and will file a bug report.
I have sooo many bugs…all brand new gear but the buttons, plugs, automations, and app are highly inconsistent. How do I file bug reports? Thanks
support.smartthings.com
This hasn’t been fixed??? Jeez I can’t edit any of my migrated Classic app smart lighting app automations, nor create any new ones. Wtf. I have at least a dozens simple automations based on time triggers, and I thought I could just rewrite the old ones in the New app if I can’t edit them, but I still can’t. I’m growing more outraged by the day.
Is there any workaround? This bug is repeatable. Bad enough that it doesn’t allow a time to be set/edited, then it leaves the time tile superimposed until I give up and exit back to the main New app Home Screen.
I’ve seen this on my iPhone IOS 14 w/ Smart Lighting. I have to go into the iPad App to set the time.
Thanks. I don’t have it running on my ancient iPad but I’ll play with the smart lighting app on the iMac/Bluestacks until an update. Yeah, my primary is an iPhone running 14b2.2.
Yup works fine on the Android version. Grrrrr
