Alternatives to virtual switches and sensors
Smartthings has always offered the ability for even non-technical customers to quite easily create virtual devices. I am not sure the new platform will offer the same easy way to create devices of this type, especially for people who don’t have a SmartThings/Aeotec hub.
Update 30 Sept 2022. Ok, if you do have a hub, there are community-created Edge Drivers for virtual devices which reportedly work very well. But we are still waiting for an official response for the options for those of us without a hub.
If you do have a hub, Check out the quick browse list for virtual device Edge Drivers in the community-created wiki.
https://thingsthataresmart.wiki/index.php?title=How_to_Quick_Browse_the_Community-Created_SmartApps_Forum_Section#Quick_Browse_Links_for_Edge_Drivers
If you don’t have a hub, keep reading. :thinking:
So I thought I would start a thread with some of the other options. These may be much more complex than the old virtual devices. Or they may be more expensive because they involve the purchase of actual physical devices. So they won’t be right for everybody.
However, since I depend on Home Automation in a way that more physically able people may not, I am willing to at least consider some of these as potential candidates for my “must-have“ use cases. And I thought other people might find this interesting.
Please feel free to add any additional methods that would not require using the IDE.
By the way, it’s also possible that I’m being too pessimistic, and that the new platform will eventually offer an official way to easily create a virtual switch as well as a virtual sensor which can be toggled on and off. That would be great, but they haven’t promised that as yet, and I’m not holding my breath. We’ll see what arrives when it arrives.
Alternatives to a virtual device which do not require the IDE
  1. Use the official API and host your own virtual device via cloud to cloud integration.
Pros: this should Probably work as long as Smartthings identifies it as a sensor to the voice assistants.
Cons: It may be technically quite complex and requires creating a developer account and learning the new API
A Staff member has posted some of the details for this method. As noted, it might feel overwhelming for a non-technical user.
Or if you have a SmartThings hub, some community members have now created edge drivers for virtual devices. Personally, I think these are a little more difficult to use than the ones created for the old architecture, but they have a lot of functionality and will work for many people as long as you do have a smartthings/Aeotec hub.
You should be able to find these on the quick browse list for virtual devices under edge drivers.
  1. Use a real sensor and automate triggering it.
I have told the story in the past how once at work we had to bridge two systems which didn’t talk to each other and we ended up setting up a remote control toy car that we could have run past a motion sensor from the other system. Once that worked as a proof of concept, we made it look more professional by putting a fan inside a box with a sensor. The fan could be turned on from system A and that would trigger the motion sensor from system B.
There are lots of ways to do this with lots of different types of equipment depending on exactly what you want to do.
For example, turning on a small table lamp might trigger a motion sensor underneath the lamp just because of the heat of the bulb.
Fans, even tiny ones, can be very effective in triggering motion sensors.
You can trigger a contact sensor if you set up an actuator to open and close a cabinet door or a drawer. You might even be able to set up a Switchbot to push a lightweight cabinet door Or box lid open and then let it fall closed again.
So basically you are using one automated device to create a physical change in the environment that can be detected by a motion or contact sensor.
The programming side of these is usually really easy. The cost and challenge comes in setting up the physical change. But honestly, it can be pretty easy if you’re willing to spend the money for the right devices.
  1. use a Switchbot and have it press a flic button. Flic buttons have a number of integrations, including being able to trigger an Alexa routine.
  2. use a Philips Hue bulb instead of a virtual switch if you have two systems which don’t communicate to each other but which can each communicate with the Hue bridge.
This won’t work for use cases which require a sensor, like triggering an echo routine. But it can work fine if you just need an on/off switch for something like Ifttt or even between two otherwise not integrated home automation systems.
This works because Philips Hue is a very friendly system and happy to integrate with many different other systems all simultaneously.
The cost for this is one $15 bulb per virtual switch. Plus figuring out where to put it so the light doesn’t bug you as it goes on and off.
https://www.amazon.com/Philips-Hue-Bluetooth-compatible-Assistant-dp-B07QV9XLTK/dp/B07QV9XLTK/
Note that this method will only work with bulbs which are connected via a hue bridge. Because it’s the bridge which will make the integrations with the other systems.
  1. use an inexpensive Wi-Fi smart plug that is recognized by HomeKit or Alexa as well as by smartthings. Meross is good for this. You can get a three pack for less than $35 and this may be less obtrusive than a hue light. This is good for a lot of integrations, but it cannot be used to trigger an Alexa routine.
https://www.amazon.com/Reliable-Support-HomeKit-Assistant-SmartThings/dp/B084JD86NT
  1. If you’re looking for something you can use from the “home control“ buttons on a harmony remote, check out the LIFX $10 Wi-Fi bulb. This does not require a hub or a bridge. If you have a smartthings hub, you can use an edge driver and get local integration. Otherwise this does introduce a cloud dependency, but it works well because LIFX is visible to both harmony and to smartthings. (Thanks to @wags1 for this suggestion.)
  2. email. No, really. :sunglasses: Some systems, such as some security systems, can you send an alert by email. Then you can receive that email on some other systems and trigger events off of that.
This used to be very easy with Gmail and Ifttt, but now Ifttt can only send an email from gmail, not process a receipt. But there are other apps and methods for processing incoming mail that you may be able to substitute.
The one thing to note with this is that there is sometimes a delay while the mail gets processed, typically about 15 minutes. So it’s good for some use cases, but not all.
The biggest advantage is that it’s probably free. :money_mouth_face:
  1. if you are already using HomeKit and Homebridge, you can create virtual devices there, including a switch to turn on a contact sensor. This allows you to then create HomeKit automations for things like “door left open for 15 minutes“. Most developers for HomeBridge call these “dummy devices” instead of “virtual devices.” But you cannot use these to trigger echo routines because at present there’s no way to get Alexa to see the dummy devices. So if you go this way you have to substitute both the virtual device and the automation and the Voice assistant plus it’s a lot of work to set up and you need an additional server device. I don’t think most people are going to want to do this unless you are already using homebridge, but it is an option. (Google “Homebridge dummy sensor“ Or “Homebridge dummy switch” to find resources on this option.)
  2. VoiceMonkey is an Alexa skill that lets you create virtual buttons which are able to trigger an Alexa routine. You can activate the button using Ifttt or SharpTools or some other integrations. So this gives you some integration possibilities that most of the other methods do not except the sensor-based ones.
Summary
Well, those are a few possibilities. If you have a smartthings/Aeotec hub you can use one of the new edge drivers. If you don’t, you can Go all in on the new platform and write your own system, find a way to physically trigger a real sensor, use Hue or a WiFi smart plug/bulb as an intermediary, or use email.
Each method has pluses and minuses and some will only work for very specific use cases, but that’s what I’ve thought of so far. Also note that most of these will require buying one or even two new devices and dedicating them to serve as the proxy, so it can get expensive.
Obviously I would much rather that smartthings provide the same kinds of virtual device options that we have on the groovy platform, but so far no one has promised that. :disappointed_relieved:
One more, but this one can get really complicated…
  1. If you have a way of automating a spoken phrase (there are many different Non smartthings options for this, Although some require a strong technical background), then you can have a voice assistant like echo or Google home act on that phrase. But it’s going to come down to small details of exactly what you’re trying to accomplish and how you want to trigger it.
For example, here’s a new device, $95, which will play up to 90 different sound files, although only 30 of them don’t repeat, and that might be what you need.
Anyway, it looks like a Z wave dimmer to smartthings, and the dim level you pick determines which sound file plays.
That might work really well for triggering Echo routines, for example, although doing the initial recording of the sound files might be tedious.
https://www.econetshop.com/soundalert.html
