Reposted because I wasnt sure if I had replied directly to the post above me. Not familiar with the ST forum.
Eric, could you reply with a bit more information? I’ve installed your smart app and your device handler, but no matter what I do, when I go to select the “virtual switch” within your smart app, my only options are all of my door sensors. Just a brief run through of what I should do once I have both the smart app and device handler installed would be super helpful.
I get confused with the thread branching here too.
What you describe is working as designed. You select the doors you want to trigger a chime when opened. What I did was install it twice, once for the doors with a 1 minute reminder beep, and once for the garage doors with a 10 minute beep.
Note I just updated it to fix a problem with the reminder double beep stepping on the first beep, so you might want to refresh the code.
Hey Kristopher… really appreciate you code. Solved my problem! One question… Im really green at this… I want to have the beep a little longer… say 5000 Mili-sec. Can you show me exactly where I insert the “silent (5000)” in the code you reference. You mentioned between the siren commands but I didn’t get it right. Would greatly appreciate!!
I am receiving the following error in live logging when I use this:
java.lang.IllegalArgumentException: Command ‘chime’ is not supported by device of type ‘Aeon Siren’. Supported commands: [on, off, off, strobe, siren, both, test] @ line 93
[quote=“Jbell, post:1, topic:25349”]
The siren didn’t make the prettiest sounds but it was capable of 4 tones at 3 different volume levels each so I could audibly differentiate between the back and front doors being opened.
[/quote]This new device handler for the Aeon Siren supports the functionality you were originally looking for.
No signature of method: script14568169779411188152818.metadata() is applicable for argument types: (script14568169779411188152818$_run_closure1) values: [script14568169779411188152818$_run_closure1@3b097099] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
I created custom monitoring in SHM and selected open/close sensors. and configured to alert with siren. but siren blows. it is not giving beep. i was not sure where to configurei it,
can you please let me know how to configure with SHM. hope i am not asking you much. Thanks for you help
Instead of using “alert with siren”, you need to use “Audio Notifications”, choose “Custom Message” from the Notification field, and enter one of the commands, like “beep”, into the “Play this messsage” field.
Please see the Supported Commands section of this post for the list of commands that can be used and how they need to be entered.
For a detailed explanation of all the available commands, please see this post.
Team, I’m so close with this integration. The problem I have is that I’m using a different siren, D-Link DCH-Z510, when I press the button the alarm comes on but it doesnt go off. Any ideas?
For anyone with a D-Link DCH-Z510 alarm, that supports multiple different alarm tones, all you need to do is change the following part of the code:
sirens?.siren()
I’ve set my SMH siren to the emergency tone, as a result this simple smartapp was playing the emergency tone continously and never stopping. I changed this code to:
sirens?.DoorChime()
This plays the simple tone twice and stops, perfect and not obtrusive. If you want to use any of the other tones, just change as follows:
This is freaking cool. Going to try it tonight. Anyway you can create a user updateable settings, where you can enter in beep duration (in ms), number of beeps, pause duration (in ms)? Ie. 500, 3, 1000, would beep for .5 seconds, pause for a second, beep for .5 seconds, pause for a second, beep for .5 seconds (total of 3 beeps).
Then we could create multiple beep devices. Something like Single Beep, Double Beep, and Triple Beep, etc.
Thanks.
Having an issue with the siren beep as a door chime. It works maybe 70% of the time. Other times it does not beep at all. It will double or triple beep, or it will go full siren.
Would adding a pause fix that?
Also what is the correct function to use?
sleep(200)
pause(200)
silent(200)
All 3 of these were mentioned in posts above, so it’s a little confusing.
EDIT: It the correct command is pause(). I changed it to 150 as 200 was too long, and 100 sometimes did not register. Will need to do more testing but I think pause(150) will work.
I’d recommend changing the last lines of your code to this to make it more reliable.
[quote=“Scott_Barton, post:43, topic:25349, full:true”]
Having an issue with the siren beep as a door chime. It works maybe 70% of the time. Other times it does not beep at all. It will double or triple beep, or it will go full siren.[/quote]
The device handler below has a bunch of beep related features built into it and it’s very reliable:
