Using a Aeon ZW080 Siren as a door chime
At some point, I had my Aeon ZW080 Siren working as a door chime with a Beep in my devices. After an extended power outage, my SmartThings system got really messed up. My Siren still has sound options, so my custom device handler seems to be working. Or at least I think it’s a custom device handler. But there is no longer a “Beep” listed in my devices. And I cannot remember or find how I got it there! Any help is appreciated…I am kinda back to square one and I am not real familiar with this stuff!
Try this device handler.
I believe this is the device handler that I have. I am already using the siren to Alarm if my doors, windows, etc are open while the house is armed. For that, I have a default tone set. But I can’t remember how I went about having a door chime working with a different tone.
You need to use the Audio Notification feature to select the device and select Custom Message from the list of sounds.
If you want to use the beep settings you specified you can enter: beep
If you want to use one of the 6 preset custom beeps you can enter “custombeep” and 1-6 like: custombeep1
I am trying to make this work the same as the guy above, but I cannot find the “Audio Notification feature”. All I have is the page with the colorful alarm and beep buttons, and when I click on settings, there is only options to select siren and beep sounds, volume and duration etc.
How do I associate a door sensor to beep the ZW080? Please assume I am a novice to the handler/app world and do not have the coding skills some of you may have. I’ve installed the handler and updated it to my device… that’s about it.
You need to use a SmartApp…
Smart Home Monitor and Speaker Companion are both built-in SmartApps that have that feature. In the Classic Mobile app go to Automations, click the “SmartApps” tab, and there’s an “Add SmartApp” option at the bottom of that screen.
