drewg123:
I just received a VISION ZM1601US-5 Z-wave PLUS Wireless Siren & Strobe Alarm, Battery Type, Gen5 from Amazon. I set up the Beep and Siren Beep as instructed above.
However I want the beep to be shorter. Is there a way to do that?
That’s the same device as the GoControl/Linear Siren and the response time is unreliable. The device handler below provides your best chance for using it as a beep device, but you’ll probably find that the beep is sometimes a lot longer than you want it.
I won’t be converting the GoControl/Linear/Vision Siren DTH into an Edge Driver so it will stop working once the Groovy platform is retired, but it probably doesn’t need a custom driver.
This is a new device handler for the GoControl Siren, Linear Siren and possibly some other generic sirens. Model: WA105DBZ-1
This device handler supports the following capabilities:
Alarm
Battery
Music Player
Polling
Switch
Tone
MAIN SCREEN
[image]
The main screen displays the current state of the device and allows you to turn on/off the Siren, Strobe, Siren/Strobe and also play the Beep tone.
Be aware that there are settings that can override the functionality of the siren, strobe, and both buttons.
SETTINGS
[image] [image]
Automatically turn off after:
Turns the device off after certai…
