Wondering if anyone can shed some light on this, I have 2 Aeon Labs Micro Dimmers, Smartthings seems to loose connectivity with them after a couple of hours.
They come back for a few hours once every 24 hours but drop off again with in 7-8 hours.
How far from your hub are they? Do you have other powered z-wave devices in your setup, so you have a robust mesh? If the Aeon’s are in a wall outlet box, they need a good mesh to stay connected.
The SmartThing outlets are zigbee, so you can put them back – they aren’t part of the problem or the solution. Probably you need some more z-wave devices to get a better mesh. Is your hub close to any other electronics? If so, moving it even a few feet may make a difference.
