I was unable to get it to connect to my hub. I then found a post ( Aeon Labs Energy Meter clamps ) that mentioned using the Aeon Labs Minimote ( http://www.amazon.com/gp/product/B007J26PIS/ ). So I bought the Minimote also. The Minimote connected to the hub without issue but when I push the button for it to include things and plug in my Energy Monitor it still will not connect to the Hub. I have searched and can’t find anything and I have asked within other threads and several PM’s and have not gotten any responses. Can anyone help me figure out how to connect this thing to my hub?
How far are you from the hub? If your Aeon is inside your circuit breaker panel the signal can be reduced. I have mine within five feet of a GE Z-Wave receptacle and don’t have a problem. I didn’t use the minimote.
I have tried putting the hub into exclusion mode and plugging in the Energy Monitor, but nothing happens. When I tried to include it again nothing happens. The light on the Energy Monitor just keeps blinking. Is that the status LED you were referring to?
Is your house stucco on the outside? If so there is a “chicken wire” like mesh beneath that can sometimes be pretty good at blocking RF. Try bringing the clamps close to hub during inclusion.
Well I feel stupid now. I didn’t notice the button inside the meter before. I thought when you plugged it in it immediately went into pairing mode and that is why the LED was blinking. I have it connected now. Thanks for the help.
I’m having the same issue trying to pair my device. I get a slow blinking red LED and I tried pressing the button inside the battery compartment but still no luck pairing. What were you able to do in order to finally pair it?
nevermind… I figured it out by trial and error. Holding down the button under the battery cover while powering on the device seemed to get it in a pairing mode. The user documentation is quite awful, it has no mention on how to pair it.
