@MEarly; @ogiewon, @Omyn, @Jmtyra, and anyone else who is interested!
I’ve got my washer and dryer CoRE pistons set up and working and receive washer and dryer notifications, and they appear to work properly. I’ve edited the DTH to label all the settings that have been appearing in Preferences (some were blank, no labels) and fixed a few errors in my code (I think!
) where I had not updated things properly.
I’d still like to do a couple more updates:
- Add reporting frequency (currently managed in the Configuration section of the code) to the Preferences - don’t know how (or if it’s possible) to do that.
- ID what kWhDelay and detailDelay settings do - I don’t understand what they affect.
- If kWhDelay and deatilDelay aren’t useful for users to edit, remove them from Preferences. (They showed up there unlabeled before I added them to the Preferences section of the code.)
If you (or anyone) sees any errors or problems w/the code, please fire away!! This is my first time sharing back modified code, kinda fun.
In-progress update of Mike Maxwell's HEM Laundry monitoring device for Aeon HEM V1. Includes customizations
from Ogiewon and MEarly.
SmartThings thread: https://community.smartthings.com/t/aeon-home-energy-meter-v1-read-clamps-separately/25480/100?u=danabw
Status:
1. Done: Ogiewon - Fix reported number of buttons so both are announced/available in SmartApps
2. Done: MEarly - Set Washer/Dryer On=pushed event; Washer/Dryer Off=held event. Allows notifications at start/end of cycle, & start/stop logging under Recent Activity.
2. Done: Danabw - All Preferences entries labeled
3. Need help: 1) Add reporting frequency setting to preferences (currently only managed in Configuration section, not available in preferences
4. Need help: 2) ID what KWhDelay and detailDelay settings control, and remove them from Preferences if user control not necessary
metadata {
definition (name: "In-progress update of Maxwell's Aeon HEM V1 Laundry DTH", namespace: "MikeMaxwell", author: "Mike Maxwell")
capability "Configuration"
capability "Switch"
capability "Button"
//capability "Energy Meter"
capability "Actuator"
capability "Holdable Button"
capability "Sensor"
attribute "washerWatts", "string"
attribute "dryerWatts", "string"
attribute "washerState", "string"
attribute "dryerState", "string"
// command "configure"
fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
preferences {
input name: "c1Name", type: "text", title: "Clamp 1 device (e.g., Washer)", description: "", required: true
input name: "washerRW", type: "number", title: "Minimum watts device draws when running:", description: "", required: true
input name: "c2Name", type: "text", title: "Clamp 2 device (e.g., Dryer)", description: "", required: true
input name: "dryerRW", type: "number", title: "Minimum watts device draws when running:", description: "", required: true
input name: "voltageValue", type: "number", title: "Line voltage: 120 or 240", description: "", required: true
input name: "kWhCost", type: "number", title: "Cost per kWh", description: "", required: true
// Not sure what kWhDelay is or does. Not sure how to remove it from the Preferences screen - it displaye w/no label before I created this entry.
input name: "kWhDelay", type: "number", title: "kWh Delay", description: "", required: true
// Not sure what detailDelay is or does. Not sure how to remove it from the Preferences screen - it displaye w/no label before I created this entry.
input name: "detailDelay", type: "number", title: "Detail Delay", description: "", required: true
// Would like to add an entry in Preferences to set the HEM reporting frequency (it is included in the Configuration
// section at the end of the code, but I don't know how to do that. :)
simulator {
tiles(scale: 2) {
multiAttributeTile(name:"laundryState", type: "generic", width: 6, height: 4, canChangeIcon: false){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
// attributeState "on", label:'Laundry Running', icon:"st.Appliances.appliances1", backgroundColor:"#53a7c0"
// attributeState "off", label:'Laundry Done', icon:"st.Appliances.appliances1", backgroundColor:"#ffffff"
attributeState "on", label:'', icon:"st.samsung.da.dryer_ic_dryer", backgroundColor:"#79b821"
attributeState "off", label:'', icon:"st.samsung.da.dryer_ic_dryer", backgroundColor:"#ffffff"
tileAttribute("device.switch", key: "SECONDARY_CONTROL") {
valueTile("washerState", "device.washerState", width: 3, height: 2, canChangeIcon: true) {
state "default", label:'Washer\n${currentValue}'
valueTile("dryerState", "device.dryerState", width: 3, height: 2, canChangeIcon: true) {
state "default", label:'Dryer\n${currentValue}'
standardTile("washerState", "device.washerState", width: 3, height: 3, canChangeIcon: true) {
state "off", label:'${name}', icon: "st.samsung.da.washer_ic_washer", backgroundColor:"#ffffff"
state "on", label:'${name}', icon: "st.samsung.da.washer_ic_washer", backgroundColor:"#79b821"
standardTile("dryerState", "device.dryerState", width: 3, height: 3, canChangeIcon: true) {
state "off", label:'${name}', icon: "st.samsung.da.dryer_ic_dryer", backgroundColor:"#ffffff"
state "on", label:'${name}', icon: "st.samsung.da.dryer_ic_dryer", backgroundColor:"#79b821"
valueTile("washer", "device.washerWatts", width: 3, height: 2, decoration: "flat") {
state("default", label:'Washer\n${currentValue} Watts', foregroundColor: "#000000")
valueTile("dryer", "device.dryerWatts", width: 3, height: 2, decoration: "flat") {
state("default", label:'Dryer\n${currentValue} Watts', foregroundColor: "#000000")
standardTile("configure", "device.configure", width: 2, height: 2, inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main "laundryState"
details(["laundryState","washerState","dryerState","washer","dryer","configure"])
def result = null
def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result) {
log.debug "Parse returned ${result?.descriptionText}"
return result
} else {
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
//log.info "mc3v cmd: ${cmd}"
if (cmd.commandClass == 50) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 1, 0x31: 1])
if (encapsulatedCommand) {
def scale = encapsulatedCommand.scale
def value = encapsulatedCommand.scaledMeterValue
def source = cmd.sourceEndPoint
def str = ""
def name = ""
if (scale == 2 ){ //watts
str = "watts"
if (source == 1){
name = "washerWatts"
if (value >= settings.washerRW.toInteger()){
//washer is on
sendEvent(name: "washerState", value: "on", displayed: true)
//button event
if (!state.washerIsRunning)
sendEvent(name: "button", value: "pushed", data: [buttonNumber: 1], descriptionText: "Washer has started.", isStateChange: true)
state.washerIsRunning = true
} else {
//washer is off
if (state.washerIsRunning == true){
//button event
sendEvent(name: "button", value: "held", data: [buttonNumber: 1], descriptionText: "Washer has finished.", isStateChange: true)
sendEvent(name: "washerState", value: "off", displayed: false)
state.washerIsRunning = false
} else {
name = "dryerWatts"
if (value >= settings.dryerRW.toInteger()){
//dryer is on
sendEvent(name: "dryerState", value: "on", displayed: false)
//button event
if (!state.dryerIsRunning)
sendEvent(name: "button", value: "pushed", data: [buttonNumber: 2], descriptionText: "Dryer has started.", isStateChange: true)
state.dryerIsRunning = true
} else {
//dryer is off
if (state.dryerIsRunning == true){
//button event
sendEvent(name: "button", value: "held", data: [buttonNumber: 2], descriptionText: "Dryer has finished.", isStateChange: true)
sendEvent(name: "dryerState", value: "off", displayed: false)
state.dryerIsRunning = false
if (state.washerIsRunning || state.dryerIsRunning){
sendEvent(name: "switch", value: "on", descriptionText: "Washer and/or Dryer running...", displayed: true)
} else {
sendEvent(name: "switch", value: "off", displayed: false)
//log.debug "mc3v- name: ${name}, value: ${value}, unit: ${str}"
return [name: name, value: value.toInteger(), unit: str, displayed: false]
// Handles all Z-Wave commands we aren't interested in
//log.debug "Unhandled event ${cmd}"
def configure() {
log.debug "configure()"
initialize()
def cmd = delayBetween([
//zwave.configurationV1.configurationSet(parameterNumber: 100, size: 4, scaledConfigurationValue:1).format(), //reset if not 0
//zwave.configurationV1.configurationSet(parameterNumber: 110, size: 4, scaledConfigurationValue: 1).format(), //reset if not 0
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 2, scaledConfigurationValue: 120).format(), // assumed voltage
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: 0).format(), // Disable (=0) selective reporting
zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, scaledConfigurationValue: 10).format(), // Or by 10% (L1)
zwave.configurationV1.configurationSet(parameterNumber: 10, size: 1, scaledConfigurationValue: 10).format(), // Or by 10% (L2)
zwave.configurationV1.configurationSet(parameterNumber: 20, size: 1, scaledConfigurationValue: 1).format(), //usb = 1
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6912).format(),
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 30).format() // Every 30 seconds
], 2000)
return cmd
def installed() {
configure()
def updated() {
configure()
def initialize() {
sendEvent(name: "numberOfButtons", value: 2)
