I have core set up to wait for a “button press” from the modified HEM DTH that treats the HEM like a two-button device, with watts settings to “push” or “hold” each button.
If button 1 (clamp 1, on the washer line) goes to 10 watts (which it does at the start of a new load) the HEM reports a “press” of virtual button 1. My piston is set to start a timer when that push occurs, and then send me a text after 45 minutes.
I haven’t actually used the piston yet (no dirty laundry) but expect it to work…
This is the HEM DTH I use, developed by others, minor modifications by me. It reads clamps separately, and makes the clamp appear like a virtual two-button device, so you can wait for button presses that occur based on settings in the DTH to push or hold the devices’ two virtual buttons based on watts readings.
