I didn’t write that DTH, I was just trying to troubleshoot the issue outlined in this topic’s subject. This thread is now getting way off original topic.
This addition to the DTH was to only solve this one issue.
If you’re having the issue, you can still use this DTH to reset your HEM, but afterwards you’re probably going to want to use a better DTH. The one that I used to fix this issue was written in 2014.
In order to get the fix, install this DTH, hit ‘configure’ (cog icon) and you’re done.
I was on firmware 3.60 and contacted support after owning it for a few days. the power data kept reporting random large spikes when no extra power was being used. support told me to update to 3.67. after doing that i no longer get power readings. only getting the following values:
Later models report current (AMPs) and are zwave plus. I mainly use the devices to monitor on/off state so I’ve found v1 to work fine. Using johnconstantelo DTH my V1 power readings are within a couple $'s of my providers #'s.
