I currently have a 3 hub configuration, 1 hub 2 sub hubs. For WiFi it’s easy to see the devices connected to each hub but zigbee and Zwave its not obvious. With the new update and the device routing information now in the IDE they all report connected to the main hub. The reason I’m asking is because the RSSI values reported for some devices is lower than -70dbm, these are devices very close to a sub hub. How do you know if the extender function of the sub hubs is operating as it should?
I have asked this question several times to support and their answer is always the same. “There is currently no way to tell if the hubs are working as extenders.”
