Adding smartapp later
When I add a device (let’s say a motion sensor) I’m asked to do some actions, like trigger a light when there is some action.
This will automaticaly add a smartapp to the device.
How to add some more smartapps after device creation ?
All I can see is creating (from a template) a new smartapp through the developper website. Am I wrong ? Am I missing something ?
Thanks.
If you want to use some of the smart apps that have been officially published, they’re available in the mobile app under the marketplace section.
Tap on the multicolored asterisk at the bottom right of the screen, then choose smart apps. They’re organized into functional areas.
If you want to add a new smart app from custom code using the IDE, this should explain:
OK found it.
Thanks.
