The button to install a SmartApp is missing. I called support and they said that it has been removed and it is no longer supported. Is that correct and if so is there another way to install a SmartApp?
That is incorrect. Go to the Automations tab > + in the upepr right > add routine > Discover tab and scroll to the bottom.
It’s there for me on iPhone. maybe I do have developer mode turned on, so that may be worth noting.
Oh, right! That was a change from a couple of versions ago. @jkp
has a write up on it:
FAQ: Did we lose the ability to add custom smartapps after the app update of June 2021?
