[§§Duplicate Thread§§]
Running ST on Android. Have a Github acc etc, have added ST SApps before. I just added the Hayward Omnipool in the graphapi portal, but can’t add it in the phone app… no add button anywhere… help please. thanks!
Go to Automations tab, add routine, go to discovery on lower right corner, and scroll down to add smart apps
There are at least four existing threads on this issue.
First you have to activate developer mode, and then as @Paul_Oliver mentioned, you will be able to do it from the Discover tab under add an automation in the smartthings app. But again, they’re already multiple threads on this, a couple just added in the last 10 days or so.
Thanks JD… I had all that done. I finally figured out that adding new ST SAs is done via Discovery in Routines… Thanks for nothing Smartthings… sheesh.
Yeah… thank PO. What a crappy UX.
