Are you familiar with using custom code? You will need a custom device type handler to be able to access the buttons.
Did you search the forum for the brand and model number, you should have found the following pretty quickly: ( The topic title is a clickable link)
If you haven’t used custom code before, it’s pretty straightforward. Basically you will copy the author’s code and paste it into your account.
See the community FAQ for a description of the terms and process:
