PEQ modded multi-way on off toggle switch
July 7, 2015
This SmartApp /Device combo uses a modified PEQ door open/close sensor wired to SPDT (3-way) switch to toggle on and off a GE Link Light or similar light or switch. The intent is to have a simple and inexpensive battery operated replacement for a standard wall switch to operate a single, 3-way or multi-way zigbee or zwave light or switch.
The PEQ Door open/close sensor can be easily modded and wired to a 3-way switch by replacing the magnetic reed relay with 3 wires soldered to the 1 reed common pad and 2 reed pads on the PCB.
A future version will be published to toggle on/off multiple switches simultaneously, and to set the dimmer level.
I will be posting the complete app and device mod description shortly.
* PEQ modded multi-way on off toggle switch
* July 7, 2015
* This SmartApp uses a modified PEQ door open/close sensor wired to SPDT (3-way) switch to toggle on and off
* a switch that controls a GE Link Light or similar light or switch. The intent is to have a simple and inexpensive battery
* operated replacement for a standard wall switch to operate a single, 3-way or x-way zigbee or zwave light or
* switch.
* The PEQ sensor has been on sale intermittently at Best Buy for under $20, and the 3 way SPDT wall switch costs a few
* dollars at any hardware store, so you can put the whole thing together for about $25.00.
* The PEQ door open/close sensor can be easily modded and wired to the 3-way wall switch by replacing
* (deslodering the relay and resoldering three wires) the magnetic reed relay with 3 wires soldered
* to the 1 reed common pad and 2 reed switch pads on the PCB. I will be posting a detailed HOW-TO for
* modification of the PEQ Sensor on the Smartthings community board shortly.
* A future version will be published to toggle on/off multiple switches simultaneously,
* and to set the dimmer level.
* Copyright (c) 2015 Joel Goldwein (goldwein at gmail.com)
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Multi-way On/Off Toggle Switch Using a Modded PEQ Door Open/Close Sensor",
namespace: "JWGThings",
author: "Joel Goldwein (goldwein at gmail.com)",
description: "PEQ multi-way On/Off Switch - This SmartApp uses a modified PEQ door open/close sensor wired to SPDT (3-way) switch to toggle on and off a GE Link Light, similar light or switch. The intent is to have a simple and inexpensive battery operated replacement for a standard wall switch to operate a single, 3-way or multi-way zigbee or zwave light or switch.",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png"
preferences {
section("PEQ sensor switches") {
input "contact1", "capability.contactSensor", title: "Which Switches?", required: true, multiple: true, submitOnChange: true
// What light should this app be configured for?
section("Turn on/off a GE Link Light...") {
input "switch1", "capability.switch", title: "Which Light", required: true, multiple: false
// section() {
// input "battery1", "capability.battery"
def installed() {
// def batteryValue = battery1.latestValue("battery")
// log.debug "latest battery value: $batteryValue"
// subscribe(battery1, "battery", batteryHandler)
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(contact1, "contact", contactHandler)
//def batteryHandler(evt) {
// log.debug "battery attribute changed to ${evt.value}"
def contactHandler(evt) {
def cname = "${contact1.displayName}"
def lname = "${switch1.displayName}"
log.info "Triggered. PEQ sensor was $evt.value and $lname was $switch1.currentSwitch"
// The contactSensor capability can be either "open" or "closed"
// Originally, I programmed this so that if it's "open", it would turn ON the light if the light was off,
// or turn OFF the light if it was on!
// And, if it was "closed" turn ON the light if it is off, or OFF the light if it is on...
// However, the Sensor state is not relevant and what was only important was the state change,
// and that change would need to trigger the light itself to change states. Thus, the code below.
// ========= Original Code ==========
// if("open" == evt.value && "on" == switch1.currentSwitch ) {
// switch1.off()
// } else if ("open" == evt.value && "off" == switch1.currentSwitch ) {
// switch1.on()
// else if ("closed" == evt.value && "on" == switch1.currentSwitch ) {
// switch1.off()
// } else if ("closed" == evt.value && "off" == switch1.currentSwitch ) {
// switch1.on()
// // I'm going to try doing this with a SPST switch
// else if (null == evt.value && "on" == switch1.currentSwitch ) {
// switch1.off()
// } else if (null == evt.value && "off" == switch1.currentSwitch ) {
// switch1.on()
// ======= End of Original Code ======
// ======= New Stateless Code ======
// Code is triggered any time there is a state change in the door sensor
// Eventually, I'm going to try doing this with a SPST switch instead of a SPDT switch
// If the light is ON
if ("on" == switch1.currentSwitch ) {
// Turn it OFF
switch1.off()
// and if the light is OFF
} else if ("off" == switch1.currentSwitch ) {
// Turn it ON
switch1.on()
// Send a info message
log.info "PEQ switch $cname is now $evt.value and $lname is now $switch1.currentSwitch"
