Can you please email support@zebrablinds.com, we haven’t tested this on hubitat but if it’s happening on it as well we would like to get more information. Also please email in any logs you can get from hubitat as well as I would like to submit it to Graber.
Right now the only confirmed sources are ST and Hubitat. We haven’t had any reports of problems on Wink, Homeseer and Vera (which we actively sell the shades to as well).
I installed my Bali motorized shade. Configured it with smartthings and set up automation.
Shade operates as expected however, after a while the shade shows up as unavailable in smartthings and will not respond to Smartthings, Alexa or the automated scenes. As soon as I use Bali’s 2 button remote to raise or lower the shade, the status returns to “on” in smartthings and all is good. Any ideas on how to keep it in an “ON” status?
How far are the shades from the hub? It could be one of 2 things. One the shade drops the signal from the hub because the mesh isn’t strong enough or two, the motor is not waking itself from sleep like it’s supposed to in which case you might have to get it warrantied.
Try checking if it’s a range issue first. If that fails try a motor reset. You can find the instructions on the first post.
@ZebraBlinds, It’s been about a year since I last explored these shades. Has there been any announcement or hint of offering this in a skylight shade? What options would you recommend for motorized cellular skylight shades?
For skylight the z-wave shades aren’t available, however, our current motorized skylight shades will be receiving a smart controller at the end of the year. Essentially works like the mylink bridge/a glorified remote controlled using a phone or schedule. It will initially only work with the app it comes with but IFTTT support is planned.
Feb 1 - April 30th, 2018 - Have a chance at receiving your order for free!*
We are running a video contest and all orders placed from Feb 1 - April 30th are eligible. Final submission date is June 30th, 2018. Prices start at a $3000 credit on your order in the US and start at $2000 in Canada. There are multiple prices available. For more information please click the links below: USA:https://www.zebrablinds.com/video-contest-show-your-stripes-colors Canada:https://www.zebrablinds.ca/show-your-stripes-colours
Neal, I looked at the event list from the device and noticed it was going offline one hour and back online the next. The automation would work if it hit at the correct time. Based on some other z-wave issues I moved my smart things hub further from my router. It was originally on the same shelf about 2 feet away, I moved it about 6 feet away and haven’t had an issue since.
Neal. This is the log prior to moving the hub.
Again no issues since moving it.
online Your SmartThings device Shade is now online
2018-04-07 6:09:33.051 PM EDT
3 days ago COMMAND ping ping command was sent to Shade
2018-04-07 5:37:33.047 PM EDT
3 days ago DEVICE activity offline Your SmartThings device Shade is now offline
2018-04-07 5:36:29.986 PM EDT
2018-04-07 5:04:23.800 PM EDT
2018-04-07 4:32:09.183 PM EDT
3 days ago DEVICE activity online Your SmartThings device Shade is now online
2018-04-07 4:32:08.207 PM EDT
2018-04-07 4:00:08.200 PM EDT
2018-04-07 3:59:05.657 PM EDT
2018-04-07 3:26:55.528 PM EDT
2018-04-07 2:54:41.870 PM EDT
2018-04-07 2:54:40.980 PM EDT
2018-04-07 2:22:40.968 PM EDT
2018-04-07 2:21:38.121 PM EDT
2018-04-07 1:49:22.533 PM EDT
4 days ago DEVICE activity online Your SmartThings device Shade is now online
2018-04-07 1:49:22.084 PM EDT
4 days ago COMMAND ping ping command was sent to Shade
2018-04-07 1:17:22.076 PM EDT
4 days ago DEVICE activity offline Your SmartThings device Shade is now offline
2018-04-07 1:16:19.542 PM EDT
2018-04-07 12:44:12.499 PM EDT
2018-04-07 12:12:04.489 PM EDT
2018-04-07 11:39:55.243 AM EDT
In general, your ST hub’s distance from your router shouldn’t have much of an effect on z-wave signal transmission. Z-wave operates on a different frequency than WiFi.
It’s entirely possible that moving your hub helped with some z-wave signal issues you were having, it’s just unlikely that the reason it helped was that the hub is now farther away from the router.
Zigbee, on the other hand, is also on the 2.4 GHz frequency. So if someone is noticing a problem with one or more zigbee devices, moving the hub away from a source of 2.4 GHz interference (i.e. the WiFi radio in the router) could help in that case.
Thanks Mark, Could it have been more electrical interference than wifi. The hub was sitting on top of a couple nas drives, next to the router and modem. With everthing plugged into a surge protector right behind it.
Hi Neil, I haven’t heard anything from support in a while. Has the issue where the shades don’t complete their open or close events been figured out yet? I have more blinds I would like to order, but just can’t do it until the ones I already have work correctly.
We’re pretty certain we’ve identified the issue and as mentioned earlier we are a 100% certain it’s an issue with ST and at this point Hubitat. We are doing some additional tests to see what can be done. Over the next week you should see me post an update asking for people to try things just so we can get some more data as well as workarounds.
Another thing we are also certain of is that it’s only impacting the roller motors even though both the roller motors as well as the ones used on the other shades run the same firmware from Somfy.
Would love some advice – I just set up a pair of Autoview shades and remotes and after some trial and error managed to get all of the devices included in SmartThings setup. I can control the blinds perfectly from the app and the remotes.
I then go to try to add them to my Google Home – I unlink my ST account and relink, but no blinds… Hmm.
I go to the Google SmartApp and untick “Allow Google to access all devices…” box, and see three categories of devices that I can select from to share, Switches, Thermostats, and Heaters (the latter two are greyed out for me, I have none of these in my ST setup.) My blinds not included under switches. Is this a Google issue? Or a ST issue?
My blinds are using the “Springs Window Fashions Shade” DH – this is what came up automatically. Should they be using a generic dimmer DH? I’m hesitant to monkey too much without some advice.
