Or if it generates revenue for Samsung?
True datā¦
Nothing because Samsung has locked me out from adding anything. I canāt even add back devices that have fallen off.
Thatās rough.
I had the same issue. If youāre on Android and have a spare phone, STās App version 1.8.07.23 will let you bypass the limit. I installed that version from APKMirror on an old phone (Note 9). Once I get a device is onboard, I switch back over to my daily driver (S22 Ultra) and configure the device (Name, room, etc.) I finally, just today, got all of my devices moved off of my older v3 hub to a new v3 hub. Factory reset my empty v3 hub and made it a secondary hub (that was good timing, since that feature was recently released). I now have 268 devices in one location, 96 of those are on my old v2 hub (dedicated to security devices and functions.) The remainder (172) are loaded on my v3 hub.
Yeah, thanks but Iām on iOS.
I may just grab a cheap Android device for this workaround.
Yeah, just for fun I tried loading STās on a BlueStacks virtual phone and it wouldnāt install. That would have been handy if it would have worked.
@JDRoberts I donāt think this needed to be a new thread. This is the 300 device limit issue.
Ok. The device limit has changed so many times and the documentation is so unclear. Iām not sure what the current situation is and if itās the same on both android and iOS. Is it 300 devices or 200 devices or are we talking about different limitations in different places?
In any case, the discussion definitely didnāt belong in the prime day thread.
Do you have a suggestion for what current thread to add it to?
Probably this one.
Done as suggested.
HI All, Has anyone else started to get the 300 Limit error when adding devices but when they are way below 300. Iām currently not able to add devices, and Iām at 250 devices. So not sure what has changed, does anyone know what counts towards the 300 ? Not sure what I could have 50 of, but itās the only thing I can think of
Well it should match what the Advanced Web App shows as being in the Location. So that will be all your hub devices (Matter, Zigbee, Z-Wave, LAN and any Edge child devices), schema devices, device groups, virtual devices, tags, hubs and mobile presence.
If you have a convenient way of accessing the API then https://client.smartthings.com/v5/locations should show the deviceLimit
, deviceCount
and deviceVacancies
for each of your Locations and they should correlate with the AWA.
Hi, No idea how to access the API, but Iāll type figure it out. I would say Iāll get the same answer of 250, so not sure why Iām not able to add devices. Iām trying their support desk on the phone, but Iām just being passed around. I donāt think they know
