RBoy
21
The simplest way to test would be to move the keypad close to the hub and then try it. If it starts working fine when it’s a mesh signal issue. Adding a few more repeaters should do the trick. We’ve found the Peanut ZigBee outlet to be an excellent repeater for ZigBee keypads. These keypads have a mounting backplate so it should be easy to remove them and move them around (it’ll trigger a tamper alarm but you can ignore it)
I can’t guarantee that the keypad doesn’t beep due to the “fog of war”, and that the problem happens only every couple of weeks and only at a bad time makes gathering hard data difficult. I would be interested in knowing what that beep really means. The device has a “lockCodes” attribute and data which makes me think it does not need any outside resources to verify a good code. So maybe the beep means “I’ve told the hub the code is good.” Hard to know.
RBoy
23
There are three types of beeps. One is when press any button on the keypad (most keypads don’t beep for this but instead just light up to show activity on the buttons).
The most common beep is when it communicates successfully with the hub. So if you find the keypad lights up but there’s no action from SmartThings and the keypad doesn’t beep it means the mesh has an issue, i.e. the message isn’t reaching the hub or the hub response isn’t reaching the keypad.
With this keypad model, if the keypad “loses” it’s connectivity with the mesh, then you’ll find the top row 3 arming buttons start flashing serially. If they don’t flash serially but there’s no beep that means it’s connected to the mesh but somewhere along the route the packets are being lost (in either direction). If rebooting the hub resolves the issue it may point to an issue with the hub or some repeater close to the hub.
While collecting LQI information above I noticed that although device 644D is in the route chain, it is not listed as " * zigbeeNodeType: ROUTER" like the others are. Problem?
Hub is on channel 20. I can’t find a way to set the channel band on my Ruckus Unleashed setup. i believe it is “helpfully” changing the band on its own. Now to look for a wifi analyzer for mac.
So I figured out how to set the available channel bands on the Ruckus Unleashed, you have to set up a group. Channel 1 is being used by my neighbors so I isolated my wifi to the middle band and left the upper band for Zigbee. The Metageek site says that zigbee channel 26 should be relatively unaffected by Wifi but many Zigbee devices do not support it. It would increase my flexibility if I could use it but how to I know?
I have 12 zwave devices and I don’t really have any problems with them. I can trigger the Mimolites from the phone for testing when the keypads are not functioning. They do not lock up after network rebuilds or reboots.
A disconnected device came back online after shifting the wifi channels I waited through the weekend to let things settle down but the raw device numbers do not look much better, especially on a 255 scale. I’m not sure what to make of all the devices having identical numbers now but at least I’m not having issues right now.
Street Keypad Before
Last Hop LQI: 80
Last Hop RSSI: -80 After
Last Hop LQI: 84
Last Hop RSSI: -79
Tradfri 6 feet from keypad and through 2 glass panes plus vinyl flooring and plywood sub-floor Before
Last Hop LQI: 76
Last Hop RSSI: -81 After
Last Hop LQI: 84
Last Hop RSSI: -79
Tradfri 20 ft away, open air Before
Last Hop LQI: 76
Last Hop LQI: 84
Last Hop RSSI: -79
Last Hop LQI: 68
Last Hop RSSI: -83 After
Last Hop LQI: 84
Last Hop RSSI: -79
The hub is then 30 ft or so away on the second floor.
Looks like you need an additional repeater to get signal up to the second floor.
Are there any particular architectural issues that might be blocking vertical spread? Tiled floors or ceilings, radiant heat in the floors, frequently operating ceiling fans?
Tradfri lightbulbs are good Zigbee repeaters for a SmartThings setup. You could try adding one in a ceiling fixture or hanging lamp with a Tradfri smartplug in the room above but about 2 to 3 m off to the side and see if that helps.
(If you use a hanging lantern, preferably one of wood or paper, otherwise not too much metal and definitely not colored glass)
You’ll need to do a Zigbee heal after adding those devices. Just take the hub off power for about 20 minutes and then after it comes back on the network will rebuild itself. This can take a little while, so don’t check the numbers until the next day. But if that improves them, then it’s just a backbone issue and you can figure out where you want to put the permanent repeaters to cover the vertical space.
(Another option would be to move the hub to the floor that has your Zigbee devices since zwave has a longer range.)
Thanks @JDRoberts. I have placed the devices as best as i can to go through unfinished flooring and open air. the last hop to the hub is through multiple layers of drywall but I’ve limited the distance to under 10 ft.
I actually have a Tradfri on the floor between the core and the hub but zigbee is choosing to bypass it even after a heal. If zigbee were to include this device, the hop distance would decrease from 30ft to about 15.The LQI is worse than the one on the floor below so I’ll have to track that device down and try to improve the signal. The backbone path has all 4’ tube lighting with outlets on the ceiling. That’s the expected destination when I track that device down.
I moved the 1st floor Tradfri closer to the hub by about 15 ft and rebooted the hub last night for 30 minutes.
The 1st floor Tradfri now has the same stats as the Tradfri 20 ft below it (and through the plywood floor) but the mesh has not adjusted to include it in the path. It is physically located such that it should be useful for 2 branches but is not included in either route. How quickly should I expect the mesh to adjust?
24 hours after the zigbee heal and zigbee devices that are physically in worse locations have better LQI than the one I moved and the routes have not changed. @JDRoberts, any point in doing multiple heals or for longer times?
These devices all have the hub as the next route hop.
15ft to the hub through finished floor/ceiling
Last Hop LQI: 84
Last Hop RSSI: -79
vs
Basement core, 40 ft away from hub vertically through a finished floor and a second finished floor/ceiling
Last Hop LQI: 80
Last Hop RSSI: -80
vs
Basement rear, 40 ft away from hub diagonally and below the next subfloor
40 feet would be a maximum range for Zigbee 3.0 in clear space indoors. Most hub manufacturers list a range of 10 to 20 m to account for the typical architectural features, including floors, walls, metal objects, even human beings.
All of which is to say you’re just too far away. The values you’re seeing sound appropriate for the distances you’re trying to cover through the architecture you have.
Additional Zigbee heals aren’t going to make any difference in this case.
If you don’t have a good way to bounce signal up a staircase, I go back to my earlier suggestion of putting the hub on the same floor as the Zigbee devices and counting on the Z wave devices to have the longer range.
With the floors in between the hub and the devices, you’re probably maxing out acceptable signal strength at about 10 m. not quite far enough for the set up that you have.
@JDRoberts I appreciate your help. I understand what you are saying and if adding this one into the route doesn’t help enough I do have a couple of outlets that I can use to add more. Unfortunately I have a significant amount of interior walls that makes going under prefereable.
The immediate problem I’m facing now is that the system seems to be building poorer route paths than the available devices will allow. The nodes 40 ft away from the hub are preferring to hop directly to the hub and past the node 10-15ft closer to them. Which makes me think the heal did not initiate or is not finished.
Zigbee devices choose their parent based on a number of different factors which are not available to us to see, including signal strength, whether any child slots are available, and traffic. It’s reasonable that they are picking the hub when the other devices have poor signal strength to the hub. It would be different if they were bypassing a device that had really good signal strength, but so far it doesn’t look like you have any of those.
Why don’t you try just temporarily moving one of your plugs up to the floor where the hub is, run a Zigbee heal, and then check its numbers the next day. If they’re way better, then you know it’s a range issue.
