Hello. I wad wondering if someone could help me out. I purchased 2 tilt sensors for my garage doors from Monprice. I paired the first without issue. The second would not register as a connected device. I noticed that the led light was solid like it was paired already. I took the 2ND device down and was able to trigger the first paired tilt sensor as open and closed by moving the second sensor. I then did a general device exclusion to the second sensor. I was able to get it to pair but the first sensor was deleted from my room “garage”. It’s like both sensors are reading as one sensor. Am I doing something wrong? Thanks in advance for your help.
Did you ever find a solution? I have the same exact issue. 2 sensors from Monoprice. First one paired fine, second I can’t get it to see
Hey Gene. Yeah I removed them from my system completely then started over.
Work ok now.
Thank you for your quick reply. Did the same and now I’m good to go. Thanks!!
No sweat. Weird stuff. Glad it worked out.
