Well i looked at my panel and my ground is already bonded with my neutral.
But I talked with an electrician, and he said I could use my ground for that purpose on this switch, because my ground and neutral are bonded. And it works.
Now… I have already been getting quotes for service and panel upgrades before knowing that they were bonded, but that really needs to be fixed.
I will just get those micro switches, because they would work exactly how I want them to.
Are they pretty reliable, and what are the differences between the 1st and 2nd gen?
Quite a few people are using them, you should be able to finds lots in the forums.
The new generation is smaller, which helps fit into more places, and I’m not sure, but I think they may have addressed the terminal attachment issue, which was pretty delicate in the first gen.
so amazon sent me the old version. (i got them in warehouse deals) and it does not require a neutral and it works just fine with my leds… cree and phillips.
are there any problems with the old style GE zwave dimmers?
Ikem… can you state the exact model number of the GE/Jasco dimmer you are using which doesn’t require a neutral and works with your Cree LEDs? I need one… thanks!
The GE models that don’t require a neutral have been discontinued by the manufacturer, but you can still sometimes find them.
Whether they’ll cause LEDs to flicker depends very much on usage and the specific fixture (not just the switch) which is why they’ll work for some people and not others. Usage is because some set ups get flickers at full on while others get flickers at about 20% and lower. If you only dim between 50% and 90%, as many people do, you may never see the flickers.
So the switch may be acceptable to some people, not to others, and it’s impossible to predict in advance which is why GE discontinued them.
Cooper still makes a zwave dimmer switch that doesn’t require a neutral and is intended only for incandescents. All the same issues apply. Some people will be happy using it to control LEDs, some won’t, just depends on the fixture and the usage.
Thanks guys. I ordered the GE/Jasco 45612 dimmer model, which arrived today. I don’t need the dimmer capabilities… just need something that will be full on when motion is detected and full off when not detected.
After installing the dimmer, this device is technically working without the neutral wire (since I have no neutral in the box). However, when it is “off”, the small trickle of electricity it requires to power the zwave chip is keeping the bulbs on at a very low (dim) setting. The bulbs I am using are LED: TCP RLR209W50KD LED R20 - 50 Watt Equivalent (9W) Daylight (5000K) Dimmable Flood Light
If I were using incandescent bulbs, it would probably work perfectly. @ikem - could you tell me exactly which cree bulbs you are using successfully with this dimmer? Thanks!
Sorry, not really clear on your question. Do you mean how to install a micro switch at the light fixture? Because there is usually a neutral there if your line hot from the circuit breaker is routed to the light fixture instead of the switch box.
