Zooz Z-Wave Plus S2 Outdoor Motion Sensor ZSE29
Which edge driver are you using successfully with the Zooz Z-Wave Plus S2 Outdoor Motion Sensor ZSE29? I am using the Zooz Multusesor driver and it is having some issues.
But, that same driver works great with the Zooz 700 Series Z-Wave Plus 4-in-1 Sensor ZSE40 and Zooz Z-Wave Plus S2 Motion Sensor ZSE18 devices though.
What are the issues?
When I open the outdoor sensor device in the app, I get a warning message. “Couldn’t get devices status”
That typically happens when one of the attributes didn’t get populated when the device was added.
If it’s the motion or lux tile that’s not populating then that problem will most likely go away after 5-10 minutes, but if it doesn’t or you don’t want to wait then try removing the device and then adding it again.
