For those who are looking for quick answer please scroll down 1/2 way through my post.
So I started automating my home when I was in a condo and started with the ZWAVE in wall switch/dimmers from AEOTEC. I purchased the smart things hub and it was great for my use.
When I moved into a bigger single family home I wanted to automate all the lights (at least on the main floor).
The problem I was running into was with 3 way switches. I purchased GE switch thinking I might be able to wire it but couldn’t (not really good with electrical wiring).
So I started looking at alternatives, Philips hue was one but it was too expensive at the time and I had about 60 + bulbs I wanted to replace hue had a limit of 50(mostly BR 30’s and A19’s). After seeing the limitation I started looking at the bulbs that would work natively with Smart things (as from my understanding at that time ST has hight limit of number of bulbs/ devices it can support). This is when I came across Sengled Brand of bulbs that works directly with ST hub, So when a good deal at Home depot presented itself I bought over 70 bulbs to replace every single one on the main floor. This was back in June/July.
I paired about 30 to 40 devices including 1 Smart things outlet and rest Sengled LED bulbs. After adding about 38 to 39 Sengled bulbs I could not add any new bulbs. I tried multiple things to fix the issue, I contacted Sengled support (which was useless to be honest), restarted hub, moved locations but nothing helped. Eventually I gave up and blamed the bulbs thinking there’s an issue with them. Since HD has a generous return policy I thought I’ll return these , This was back in july. Then I got busy with work and setting up the house, completely forgot about the bulbs until black friday.
I saw a deal on Amazon for the Sengled bulbs pack of 8 and bought them thinking I need more bulbs anyway and thought will exchange the ones I already had or claim warranty. I also purchased some ST multi purpose sensors. I first tried to add the ST Multi purpose sensor, even that wasn’t being recognized by the hub, after checking online reviews thought these are just PITA to sync, lets try the bulbs now. Now when I started to install the bulbs from the new pack the hub would still not recognize any new bulb. This is when my suspicion grew.
Even though It was right there in front of my eyes the whole time, I did not see that the issue could be with the Hub. I just blamed it on a bad batch of bulbs even though it was highly unlikely.
I then started researching my specific issue with Sengled LED bulbs, could not find any information.
Then I just decided to reset my hub to factory default removing all the devices I had already paired.
Once Reset the first device I paired was the ST multi-purpose sensor, I had a very clear outcome of this try in my mind. I knew it will be a pain to pair it but to my surprise the hub recognized it immediately on first try.
I was really excite and started pairing bulbs that were already paired previously thinking the issue is resolved.
Now when I again reached about 32 total zigbee devices my hub stopped recognizing some of the bulbs that were previously working.
I immediately called ST customer support, after talking to the rep on the phone and some trouble shooting he realized my hub wasn’t searching for any zigbee devices when trying to add new zigbee bulbs.
He dug in a little more and told me that Smart things has a hard limit of 32 devices for these kind of bulbs (Bulbs that are End devices / don’t act as a repeater).
He asked me to add the ST outlet and as soon as I added it i could add few more bulbs.
So now I had option of either returning the bulbs back to home depot (later found out my return window had expired 2 weeks ago) or add some repeaters/routers.
I posted my experience on this forum and @tpmanley confirmed this limit. Below is his reply to my original post.
Also @JDRoberts recommended that I try CREE connected LED as that works as a repeater/router or try some zigbee plugged in devices like outlets. He also recommended that I try to figure out how many devices each kind of repeater/router supports as the Sengled bulbs are growing in popularity.
I found some good deals on ST outlet so bought a few, bought 1 Lowes Iris outlet. Both of these works as zigbee repeaters/routers. Lowes outlet I believe works as a Zwave repeater also but you have to add it a little differently(I didn’t).
Anyway now getting to the point of the post (LOL, I know long Post. Sorry). I did some testing yesterday to find out how many devices a repeater/router can support and below are my findings.
**I tested with 32 total Zigbee End devices already connected directly to my ST hub(30 non repeating Sengled LED smart bulbs, 1 ST Motions sensor battery powered, 1 ST multi purpose sensor).
**I tried to add the same bulbs every time.
**Whenever I hit the max end device limit with repeater/router I unpaired 1 bulb and tried to add another bulb again to make sure it is recognizing the last end device and I have actually hit the limit.
I will provide 2 numbers below for each product I tested
1> Max zigbee end devices on ST
2> Number of devices the repeater can add.
The reason for me providing max zigbee end devices is because one of the repeater is counted towards the 32 Zigbee devices ST hub limit. Which means that if you have 32 zigbee end devices already connected to the hub you will not be able to add this repeater to ST hub without removing another paired zigbee end device.
Cree Connected LED
- Max zigbee end devices on ST - 35 devices (this number includes CREE led bulb)
- # of devices repeater can add - 3
(31 Zigbee End Devices on ST Hub, added–> 1 Cree Connected LED for total 32 then was able to add–> 3 Sengled bulbs)
After adding Cree bulb to ST hub as 32nd device, it let me add 3 more Sengled bulbs.
*Note - This is the repeater I was talking about above. It needs to be within the 32 end devices limit of ST hub as it is counted towards the limit( or if you use another repeater like ST outlet it needs to be within the Max supported end devices limit combine of ST hub and Outlet) CREE connected led bulb will only pair with the hub when its within the Max Zigbee end device limit.
SmatThings Smart Outlet (F-OUT-US-2)
- Max zigbee end devices on ST - 39 end devices (this number does not include ST outlet as its not
counted towards the limit)
- # of devices repeater can add - 7
(32 Zigbee End Devices on ST Hub, added–> 1 ST Outlet for total 33 devices then was able to add–> 7 Sengled bulbs)
ST outlet does not count towards the 32 end device limit. I added it on top of the 32 end devices already paired with ST hub and it paired without any issues.
After adding this outlet I was able to add 7 more Sengled Led bulb.
Lowes Iris Smart Outlet(3210-L)
- Max zigbee end devices on ST - 45 (this number does not include ST outlet as its not counted towards the limit)
- # of devices repeater can add - 13
(32 Zigbee End Devices on ST Hub, added–> 1 Lowes Iris Smart outlet for total 33 devices then was able to add–> 13 Sengled bulbs)
Not sure what factors affect the total number of end devices a repeater / router can repeat.(Maybe someone with info will chime in here).
I will be ordering a Centralite Smart outlet as I have read that Lowes Iris outlet is just re branded and repackaged Centralite outlet.
Hopefully Centralite will be able to add 13 more devices like the Lowes one.
For $ to Devices repeated, even with the Lowes Iris outlets current price of $38 it provides a better value compared to ST outlet.
Now if Centralite smart outlet is able to support 13 devices it would be a great value at its current price of $30(it has gone for $20 few weeks back).
Let me know if you would like me to test any other scenario or if you have any questions.
