I wanted to test out the code from the ZigBee example from this site: http://docs.smartthings.com/en/latest/device-type-developers-guide/zigbee-example.html, but unfortunately it wouldn’t compile. I had tons of errors from this code as listed below. Do I need to install groovy as described from: http://docs.smartthings.com/en/latest/getting-started/groovy-basics.html, or do I need to set up my ide in a certain way, or do I need to import things?
Metadata {} :
groovy.lang.MissingMethodException: No signature of method: script14681783347571255931203.metadata() is applicable for argument types: (script14681783347571255931203$_run_closure1) values: [script14681783347571255931203$_run_closure1@f37535f]
Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
capability “Actuator”:
java.lang.NullPointerException: Cannot invoke method findDTOByName() on null object
fingerprint profileId: “0104”, inClusters: “0000, 0003, 0004, 0005, 0006, 0008”:
groovy.lang.MissingMethodException: No signature of method: script146817868385290037693.fingerprint() is applicable for argument types: (java.util.LinkedHashMap) values: [[profileId:0104, inClusters:0000, 0003, 0004, 0005, 0006, 0008]]
tiles(scale: 2) {} “method” :
groovy.lang.MissingMethodException: No signature of method: script14681787213021509226521.tiles() is applicable for argument types: (java.util.LinkedHashMap, script14681787213021509226521$_run_closure2) values: [[scale:2], script14681787213021509226521$_run_closure2@6768aa0a]
Possible solutions: tiles(), tiles(groovy.lang.Closure), tile(java.util.Map), tile(java.util.Map, groovy.lang.Closure), getTiles(), pages()
I’d really appreciate any help from other developers as to what I need to do to get everything working for this code.
