OK, I’m a complete newbee. A refugee from Iris. I have a ST hub installed and I installed one GE light. Works OK!
Now I want to install the Iris Smart Fob. So, I studied this forum (so much great information) and found that a generous user had written an app for that device. I followed the directions and added the code to the developer page “From Code” When I hit the “Create” button I get an error message that means nothing to me. I tried a different app just to make sure, and I get the same type of error message. I have to assume the app is correct, so I can’t figure out what’s happening. Can’t get past that screen. I.m sure I’m doing something wrong, but I cant figure out what. Any help will be gratefully appreciated.
Here is the error message text:
No signature of method: script14723192597681316881706.metadata() is
applicable for argument types:
(script14723192597681316881706$_run_closure1) values:
[script14723192597681316881706$_run_closure1@35360523]
Possible solutions: getMetadata(), getState(),
setState(java.lang.Object), metaClass(groovy.lang.Closure)
I knew I was doing something really BASICALLY wrong, but I just couldn’t see it. Thank you so much. I added the code to the DTH page and everything worked fine. I attached the device to the handler and now it turns on and off that GE light switch. Now I have the confidence to port the many other Iris and other devices to ST.
