Ok so as I’ve stated before I’m no coder by any means but I can sometimes fiddle around enough to figure something out. Right now I’m getting an error on line 120 with this in regards to a null+null but I can’t find anything that looks funny here
metadata {
// Automatically generated. Make future change here.
definition (name: "Energy Hub Energy Meter", namespace: "thefuzz4", author: "Jason Hamilton") {
capability "Power Meter"
capability "Configuration"
capability "Sensor"
capability "Refresh"
fingerprint profileId: "0104", deviceId: "0100", inClusters: "0000,0003,0004,0005,0006,0702", outClusters: "000A"
// simulator metadata
simulator {
// UI tile definitions
tiles {
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("power", "device.power", inactiveLabel: false, decoration: "flat") {
state "power", label:'${currentValue} Watts'
main "power"
details([ "power", "refresh"])
standardTile("configure", "device.power", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
// Parse incoming device messages to generate events
log.info description
if (description?.startsWith("catchall:")) {
def msg = zigbee.parse(description)
log.trace "data: $msg.data"
} else if (description?.startsWith("read attr -")) {
def descMap = parseDescriptionAsMap(description)
log.debug "Read attr: $description"
} else if (descMap.cluster == "0006" && descMap.attrId == "0000") {
name = "switch"
value = descMap.value.endsWith("01") ? "on" : "off"
def result = createEvent(name: name, value: value)
log.debug "Parse returned ${result?.descriptionText}"
return result
} else if(descMap.cluster =="0702" && descMap.attrId == "0400") {
def value = convertHexToInt(descMap.value)/10
//Dividing by 10 as the Divisor is 10000 and unit is kW for the device. AttrId: 0302 and 0300. Simplifying to 10
log.debug value
def name = "power"
return result
else {
def name = description?.startsWith("on/off: ") ? "switch" : null
def value = name == "switch" ? (description?.endsWith(" 1") ? "on" : "off") : null
return result
def meter() {
"delay 3000", "st rattr 0x${device.deviceNetworkId} ${endpointId} 0x0702 0X0400"
def refresh() {
log.debug "Refresh Method called";
"st rattr 0x${device.deviceNetworkId} 1 6 0", "delay 500",
"st rattr 0x${device.deviceNetworkId} 1 0x0702 1024", , "delay 500"
def configure() {
log.debug "Configure Method called"
String zigbeeId = swapEndianHex(device.hub.zigbeeId)
def configCmds = [
//Switch Reporting
"zcl global send-me-a-report 6 0 0x10 0 3600 {01}", "delay 500",
"send 0x${device.deviceNetworkId} 1 1", "delay 1000",
//bind to cluster 0x702. Power Consumption
"zdo bind 0x${device.deviceNetworkId} 1 1 0x0702 {${device.zigbeeId}} {}", "delay 500",
//read attribute 1024Dec/400Hex.
//"st rattr 0x${device.deviceNetworkId} 1 0x0702 1024"
return configCmds + refresh() // send refresh cmds as part of config
def parseDescriptionAsMap(description) {
(description - "read attr - ").split(",").inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
private hex(value, width=2) {
def s = new BigInteger(Math.round(value).toString()).toString(16)
while (s.size() < width) {
s = "0" + s
private Integer convertHexToInt(hex) {
Integer.parseInt(hex,16)
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
Thank you all for your help with this.
