kimyoungkyu:
Try:
id: "MAX Electronics/SMS-107"
The id is usually “manuf/prod”.
The id is just a unique id for that fingerprint, it’s not used to match anything. Don’t ask me how I learned it
Yes, this is a just a unique identifier for the fingerprint. It only has to be unique within the fingerprints file. It so happens that for Zigbee devices Manufacturer/Model is a good starting place when trying to think of something unique.
Driver Components and Structure | Developer Documentation | SmartThings would be a good starting point had they not completely screwed up the display of the Fingerprints by putting them on one line. Still, could be worse, they could have written zigbeeManfacturer (no ‘u’) in the API. Oh they did …
The Edge reference documentation has nothing to say about fingerprints.
Thanks for your comment. I will try as your advice. Is this the reason why not being loaded my edge driver?
deviceProfileName is usually lowercase.
Maybe the manufacturer is SCIONIX?
in the “zigbee thing” , model name is "SMS-107, Manufacturer is “MAX Electronics” and “SCIONIX” is brand name..thanks
fingerprints:
id: “MAX Electronics/SMS-107”
deviceLabel: “SCIONIX SMS-107”
manufacturer: “MAX Electronics”
model: “SMS-107”
deviceProfileName: “multi-sensor-000”
Fingerprint is modified as above but the result was same unfortunately..
Start the logging of the Zigbee Thing driver, add the device, post the output here.
Make sure to add ``` before and after, like this:
Paste
model, manufacturer is correctly loaded
Before adding—
After adding–
Hub Driver–
Zigbee thing driver has following log
Driver Id Name
1 01976eca-e7ff-4d1b-91db-9c980ce668d7 Aqara Presence Sensor
2 c856a3fd-69ee-4478-a224-d7279b6d978f bose
3 9050ac53-358c-47a1-a927-9a70f5f28cee DEEPSMART KNX GATEWAY
4 4eb5b19a-7bbc-452f-859b-c6d7d857b2da Harman Luxury
5 7beb8bc2-8dfa-45c2-8fdb-7373d4597b12 JBL
6 1f03c136-a7be-409e-abaa-5da29cac75e3 Multi-Sensor SMS-107 Driver V016
7 cd898d81-6c27-4d27-a529-dfadc8caae5a Philips Hue
8 dbe192cb-f6a1-4369-a843-d1c42e5c91ba SamsungAudio
9 c21a6c77-872c-474e-be5b-5f6f11a240ef Sonos
10 d9c3f8b8-c3c3-4b77-9ddd-01d08102c84b Wemo
11 f2e891c6-00cc-446c-9192-8ebda63d9898 Zigbee Switch
12 8bf71a5d-677b-4391-93c2-e76471f3d7eb Zigbee Thing
? Select a driver. 12
connecting… connected
2025-06-09T19:16:32.533779628+09:00 TRACE Zigbee Thing Setup driver zigbee_thing with lifecycle handlers:
DeviceLifecycleDispatcher: zigbee_thing
default_handlers:
doConfigure:
driverSwitched:
child_dispatchers:
2025-06-09T19:16:32.536322793+09:00 TRACE Zigbee Thing Setup driver zigbee_thing with Capability handlers:
CapabilityCommandDispatcher: zigbee_thing
default_handlers:
refresh:
refresh
child_dispatchers:
2025-06-09T19:16:32.538033122+09:00 INFO Zigbee Thing Created dispatcher [SecretDataDispatcher]zigbee_thing that had no handlers
2025-06-09T19:16:32.540373320+09:00 TRACE Zigbee Thing Setup driver zigbee_thing with Secret Data handlers:
SecretDataDispatcher: zigbee_thing
default_handlers:
child_dispatchers:
2025-06-09T19:16:32.542215902+09:00 TRACE Zigbee Thing Setup driver zigbee_thing with Zigbee handlers:
ZigbeeMessageDispatcher: zigbee_thing
default_handlers:
attr:
global:
cluster:
zdo:
child_dispatchers:
2025-06-09T19:16:32.602798441+09:00 TRACE Zigbee Thing Zigbee Device: db93b2bf-d7bb-4df5-8f8c-732eb49af349
Manufacturer: MAX Electronics Model: SMS-107
[1]: server: Basic, 0xFC10 | client
2025-06-09T19:16:32.604723785+09:00 DEBUG Zigbee Thing driver device thread event handled
2025-06-09T19:16:32.606990728+09:00 TRACE Zigbee Thing Received event with handler driver_lifecycle
2025-06-09T19:16:32.608550624+09:00 INFO Zigbee Thing received driver startupState: {“hub_zigbee_id”:“YO+r//4kjh0=”,“hub_node_id”:null,“hub_ipv4”:“192.168.0.74”}
2025-06-09T19:16:32.624058736+09:00 TRACE Zigbee Thing Received event with handler environment_info
2025-06-09T19:16:32.626428287+09:00 TRACE Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> received unhandled lifecycle event: init
2025-06-09T19:16:32.628557514+09:00 DEBUG Zigbee Thing Zigbee Thing device thread event handled
2025-06-09T19:16:32.630121038+09:00 TRACE Zigbee Thing Received event with handler environment_info
2025-06-09T19:16:32.645284841+09:00 INFO Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> generating doConfigure event for TYPED provisioning state
2025-06-09T19:16:32.648259789+09:00 TRACE Zigbee Thing Found DeviceLifecycleDispatcher handler in zigbee_thing
2025-06-09T19:16:32.650452850+09:00 TRACE Zigbee Thing Found CapabilityCommandDispatcher handler in zigbee_thing
2025-06-09T19:16:32.652184984+09:00 DEBUG Zigbee Thing Zigbee Thing device thread event handled
2025-06-09T19:16:32.653869044+09:00 DEBUG Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> doConfigure callback did not fail, transitioning device to “PROVISIONED”
2025-06-09T19:16:32.655705705+09:00 TRACE Zigbee Thing Received event with handler device_lifecycle
2025-06-09T19:16:32.658274054+09:00 INFO Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> received lifecycle event: added
2025-06-09T19:16:32.676273088+09:00 DEBUG Zigbee Thing Zigbee Thing device thread event handled
2025-06-09T19:16:32.678038452+09:00 TRACE Zigbee Thing Received event with handler device_lifecycle
2025-06-09T19:16:32.679575917+09:00 INFO Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> received lifecycle event: doConfigure
2025-06-09T19:16:32.687920464+09:00 TRACE Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> received unhandled lifecycle event: added
2025-06-09T19:16:32.689523722+09:00 DEBUG Zigbee Thing Zigbee Thing device thread event handled
2025-06-09T19:16:32.696225234+09:00 TRACE Zigbee Thing Found DeviceLifecycleDispatcher handler in zigbee_thing
2025-06-09T19:16:32.698621303+09:00 TRACE Zigbee Thing Found CapabilityCommandDispatcher handler in zigbee_thing
2025-06-09T19:16:32.701276416+09:00 DEBUG Zigbee Thing Zigbee Thing device thread event handled
2025-06-09T19:16:32.702922327+09:00 DEBUG Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> doConfigure callback did not fail, transitioning device to “PROVISIONED”
2025-06-09T19:16:32.717677654+09:00 DEBUG Zigbee Thing Zigbee Thing device thread event handled
2025-06-09T19:16:32.951769752+09:00 TRACE Zigbee Thing Received event with handler device_lifecycle
2025-06-09T19:16:32.954542358+09:00 INFO Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> received lifecycle event: infoChanged
2025-06-09T19:16:32.959897656+09:00 TRACE Zigbee Thing <ZigbeeDevice: db93b2bf-d7bb-4df5-8f8c-732eb49af349 [0x05D5] (Zigbee Thing)> received unhandled lifecycle event: infoChanged
2025-06-09T19:16:32.961498037+09:00 DEBUG Zigbee Thing Zigbee Thing device thread event handled
Edge Driver log has nothing appeared as follow
Label Name Device Id
1 SmartThings Station SmartThings Station cdeac164-0bb7-429d-a98f-dbc363c17545
? Select a hub. 1
Driver Id Name
? Select a driver. 6
D:\SMS-107Driver>
Now paste the complete fingerprints.yml file. From the first to the last line.
This is fingerprint.yml contents
fingerprints:
model: “SMS-107”
and config.yml
name: ‘Multi-Sensor SMS-107 Driver V016’
packageKey: ‘maxelectronics.scionix.sms107 V016’
description: 'Edge driver for SCIONIX Multi-Sensor SMS-107
vendorSupportInformation: ‘http://www.jjansunyi.co.kr ’
permissions:
zigbee: {}
the meaning is not clear
Do you mean that “fingerprints:” should be replaced as “zigbeeManufacturer:” ?
