Hi.
I just purchased contact / temperature sensor model XHS2-TY , XHS2-UE Home Comcast Xfinity Security MCT-350.
After advice from this excellent forum, I selected the Zigbee Contact MC driver from a series of drivers that @Mariano_Colmenarejo created.
It’s working but the granularity is not fine enough for what I need. The 'Temperature Reportable Change’s is set to the minimum of 10, which should give a granularity of 0.1 degree. I noticed the readings are as follows:
71.6
69.8
68
66.2
64.4
66.2
68
69.8
These line up perfectly with whole number increments of degrees Celsius. I was expecting to get at least 0.1 degree Celsius changes reported? Do I need to change another setting?
SmartThings shows model URC4460BC0-X-R thanks.
