I’d like to smartify a few lights in my place. I was planning on going with in-wall dual relays to keep my current switches/dimmers as a first pass into the house of the future (ha!) and also cheaper (for now). Is this a bad approach, should I just go for smart switches/dimmers?
Vision dual-relay appears to be working ok with ST but I can’t find the monoprice anymore. Then there’s also the Fibaro (though not in canada?). I would welcome any tips… I am planning on returning my wifi based tp-link switches and outlets as I would like to keep things as local as possible without a need to go back and forth to the cloud.
As far as the Fibaro dimmer 2, It may be able to run locally now, but it is not a dual controller. The two refers to the second generation of that model, but it’s still a single controller.
The Fibaro dual relay is the “double Switch 2,” but again, I don’t think any multi endpoint devices run locally at this time.
For a canadian user. Go with Lutron. Price is similar to zigbee/Z-wave switches and there’s no comparison. I live in both countries right now and HA is not nice to Canadian for both device selections and pricing. I have Smartthings, Wink 2, Phillips, Lutron and quite a few other hub/bridge. Phillips and Lutron are my favorites. They are basic, can be found at many retailers and super reliable. I am slowly switching all my switches to Lutron since Smartthings has direct integration.
Oh this is a deal breaker then. I guess I need to get native z-wave dimmer and switch for my kitchen then. But could Dimmer 2 be combined with some sort of intensity knob and switch? I really like physical presence of a knob/slider. The manual has a lot of options but I don’t understand if this would be possible.
Sliders are usually analog while the networked devices are digital. There are some dimmer devices which use a long hold to increase or decrease dimming which has some of the same ergonomics as a slider, but I don’t think you’re going to find an actual slider.
Yes I know how those work, I have one in the bathroom with a motion sensor, from lutron I think. As of now, I can’t see why it would make sense for me not to get a smart GE dimmer with everything included, it’s even probably cheaper(!).
yeah I know pots are analog but that wouldn’t be a bad solution. Get whatever interface you like in analog then put whatever “brain” you want behind it. Then you could simply swap the brain over time and keep the same human interface…
Before you start buying anything. One advice is to look behind d the switch boxes for your wiring Config. Some won’t work with smart switches while other won’t work with in wall relay module. Especially 3/4 ways wiring.
