Z-WAVE switch - Hold / Long Press / Double Tap
Hi Friends,
I am on my next mission to build and app to trigger events when i Hold (Long Press) or Double Tap a Z-Wave switch.
Another option could be when switch already ON or OFF and i Press Once or Double Tap or Hold trigger events…
I am not satisfied by the app “Double Tap Switch” and would like to try to improve it.
Any suggestion will be very appreciated!
I gave up on timing based switch modes in favor of using states, and simply incrementing them when repeated on or off events are received.
Thank you for your answer.
I am not sure what it means…
Does it means that i can not work on a solution holding a z-wave switch ON or OFF for X seconds?
Could you provide an example of any possible solution?
Thank you!
I have found timing to be unreliable. Better to press on for scene 1, press on again for scene 2, etc. See ‘rotate ham and switch’ at:
http://www.solutionsetcetera.com/SmartThings
Let me check that…
Thank you!
Re
After checking i don’t see how the code works how you described or maybe i did not find the right smartapp.
Could you please paste the code?
Thank you.
