I just got my first Xiomi water sensor. Main issue I am facing is, when I press the pair button, light blinks for few seconds and it stops blinking. I am not sure if its normal or there is an issue with the sensor itself. I am not able to proceed with next steps of pairing with Smartthings hub due to this
I usually hold the button until it starts fast blinking, release and then single press every 5 seconds or so until it is paired.
Great. Let me give it a try once I reach home.
I was able to get it working with a lot of efforts and referring to below links.
Hi
Just received two of them but can’t figure out which DH to be used? Has anyone already added them to ST?
thanks
F
Device Handler for the cheap xiaomi zigbee plug. Since it does not pair automatically with SmartThings, you’ll have to add this device manually by using its Zigbee Id and Network Id. You can get Network Id from ST Hub. For Zigbee Id, you can get it from Xiaomi Hub/Gateway (there could be other way to figure out the Device Id). For less than 10~15$ usd, you’ll get a Zigbee Outlet and a temperature sensor.
Edit : You do not need a Zigbee Device ID for it to work.
Here’s the step
Press Add a Thing in ST App
Hold the button in the outlet for a few seconds
In IDE, you will get something like
catchall: 0104 0000 01 01 0100 00 B46D 00 04 115F 0A 01 01FF4231641000032814983900000000953900000000
Add a New Device using IDE
Fill in the Device Network ID, you can find it from the catchall log. it …
Thanks Jimmy for your help
I just received the Aqara (Xiamomi) Leak Sensor.
Couldn’t finf out how to pair, until I saw a video where the sensor was squeezed/pinched to pair it.
Press on top of the sensor and you feel it’s flexible. Press a few times and watch Smartthings to pair.
That does the trick when the Smartthings is in pairing mode.
The Device Handle is shown as “Xiaomi Aqara Leak Sensor”.
The modell nr of the sensor I have is SJCGQ11LM, with the 3V battery.
Device Handler: https://github.com/bspranger/Xiaomi/blob/776c4e036b60f1944d4937eded51a4972115b767/devicetypes/bspranger/xiaomi-aqara-leak-sensor.src/xiaomi-aqara-leak-sensor.groovy
