Thank you.
this is my code:
definition(
namespace: “smartthings”,
author: “SmartThings”,
description: “Turn things off if you’re using too much energy”,
category: “Green Living”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet@2x.png”,
pausable: true
preferences {
section {
input(name: “meter”, type: “capability.powerMeter”, title: “When This Power Meter…”, required: true, multiple: false, description: null)
input(name: “threshold”, type: “number”, title: “Reports Above…”, required: true, description: “in either watts or kw.”)
section {
input(name: “switches”, type: “capability.switch”, title: “Turn Off These Switches”, required: true, multiple: true, description: null)
def installed() {
log.debug “Installed with settings: ${settings}”
initialize()
def updated() {
log.debug “Updated with settings: ${settings}”
unsubscribe()
initialize()
def initialize() {
subscribe(meter, “power”, meterHandler)
def meterHandler(evt) {
def meterValue = evt.value as double
def thresholdValue = threshold as int
if (meterValue > thresholdValue) {
log.debug “{meter} reported energy consumption above {threshold}. Turning of switches.”
switches.off()
I made app and virtual device in phone app. it is working on simulator but it is not working well, switch just is on. when I wanted to set input in smartapp from phone, I could not make input. it gave errors.
if I do not work with classic platform which platform do you suggest me?
