My goal of the code below is to turn on a light when power consumption = 0 and between set times. As it stands, the code turns on the light when the power consumption = 0, but not within the specified time range. Looking at the code, it appears I need another If statement regarding the from/to time. Does anybody have an idea how to accomplish this?
- Energy Saver
- Copyright 2014 SmartThings
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
definition(
name: “TV Lights On”,
namespace: “smartthings”,
author: “SmartThings”,
description: “Turn things On if you’re using too much energy”,
category: “Green Living”,
iconUrl: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet.png”,
iconX2Url: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet@2x.png”,
iconX3Url: “https://s3.amazonaws.com/smartapp-icons/Meta/light_outlet@2x.png”
preferences {
section {
input(name: “meter”, type: “capability.powerMeter”, title: “When This Power Meter…”, required: true, multiple: false, description: null)
input(name: “threshold”, type: “number”, title: “Reports this…”, required: true, description: “in either watts or kw.”)
section {
input(name: “switches”, type: “capability.switch”, title: “Turn ON These Switches”, required: true, multiple: true, description: null)
section(“Turn on between what times?”) {
input “fromtime”, “time”, title: “From”, required: true
input “toTime”, “time”, title: “To”, required: true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
subscribe(meter, “power”, meterHandler)
def meterHandler(evt) {
def meterValue = evt.value as double
def thresholdValue = threshold as int
if (meterValue == thresholdValue) {
log.debug "${meter} reported energy consumption equals ${threshold}. Turning on switches."
switches.on()
