[WITHDRAWN] MyQ LiftMaster/Chamberlain
MyQ has been working flawlessly for quite some time - suddenly stopped working with ST yesterday - no joy on auto garage door opening when I return home. Also will not manually open/close the door from the device. It constantly shows CLOSED - when I hit the green circle to open it flashes OPENING quickly, then goes right back to CLOSED.
The Chamberlin MyQ iPhone app will open and close the door though.
Any ideas on how to get this working again?
The platform started having issues yesterday. There may be nothing that can be done to fix the issue in the short term (until the gremlins are killed or an exorcism is performed).
Like maybe the HUB2 update that’s scheduled tomorrow?? (I got an email about that last night)
Rules of mine (unrelated to MyQ) weren’t firing yesterday either…I saw nothing from ST…did I miss a service impacting notice?
It looks like they started some things early.
Are you running a V2 Hub? I got the email from ST Support at 3:45pm yesterday saying there was a Hub Update that would be installed Thursday between 8am - 12:00pm.
Nope…I’m an early adopter and still on v1.
I think it’s just a V2 update. Looks like they’re slowly adding in some of the functionality that was originally promised with V2.
What have you noticed that’s been added in? (joking, other than the more persistent failures)
Thanks Jason - appreciate your work!! Any chance you have RadioRA 2 and want to setup a SmartApp? :wink:
Anyone get a connection reset error? Here’s my Live Logging stream:
9b863dc0-1235-4802-ac68-160690a13164 4:36:02 PM: error java.net.SocketException: Connection reset @ line 261
The above is corresponds to MyQ(Connect) SmartApp…
All the time. Likely rate limiting on the MyQ side.
I am also trying to remove the app and it says ā€œDevice still in use. Remove from any SmartApps or Dashboards, then try again.ā€ - only problem is the MyQ (Connect) app is the only app it is still in and that is what I am trying to remove. Did you ever get instructions on how to remove?
I kept refreshing and after a few attempts it ended up disappearing.
Refreshing in the SmartThings app? I keep hitting remove in the app and it always does the same thing.
Oh no…I meant in IDE.
I turned in a support ticket and the representative couldn’t remove it. They escalated it to an engineer and I am still waiting on a response.
Hey guys, I was using the code @ https://raw.githubusercontent.com/copy-ninja/SmartThings_MyQ/master/MyQ.ServiceManager.SmartApp.groovy by @copyninja for the MyQ integration. Is there a never version or other code we are referring here? Asking it since I see a 657 reply thread running for one year :smile:
PS: I think it is time to breakup the thread… Too long and old
Nope… Too long for ST to not have official integration… Promised at CES 2015 (Jan 2015), over a year now…
https://gigaom.com/2015/01/06/smartthings-next-generation-hub-will-support-thread-and-the-oic/
http://www.reuters.com/article/nv-smartthings-idUSnBw056695a+100+BSW20150106
I see. I am onboard for that :smile:. Was there anything official on that - on why the delay?
