[WITHDRAWN] Denon Network AV Receivers
+1 for Zone 2 support!
This actually works on a 2011 Marantz SR5006! Awesome.
I don’t see why not, what make and model do you have?
Hi,
I have 2 models actually. A Denon x2200 and a 2113ci.
I’ll look into it…
What do you need to do with the zone 2. Just to be able to switch between zones?
I would think at least volume control but changing source would be useful
I created a piston in CoRe that polls the device when TV is turned on and off. It would also work well if you have a motion sensor near by. I don’t like heavy polling, but you could also schedule the ā€œrefreshā€ periodically…
I think if you switch to zone 2, then the existing volume command will operate the active zone. I’ll double check to see if there are independent volume commands…
That would make sense - good point.
Right now I use the Denon iOS app for Zone 2 to Power on/off, input change,
and volume change.
Would be great to automate with ST.
Sneak peek cleaned up the UI a little. Added the mute to the main tile. Added DVD input. Next zone 2 switch and surround modes. I am trying to cycle through the modes rather than adding individual tiles for music, movie, game and pure sound, but it’s being a pain.
Bobby, can you post your version? Thanks, M
Will do it later today. I didn’t get a chance to work on the zone 2 nor the surround modes, that’s why I didn’t publish it, yet…
How’d you get Alexa to switch inputs on the receiver? I’m scratching my head trying to get it to work.
Stop scratching and get busy installing CoRE lol…there are many ways of doing it. Core can utilize individual switches for each input
Also a virtual switch can do it. Also there was an app at the top of the thread…
This looks good please post when you can! Input switching via a single button isn’t a bad idea but I almost think individual tiles are better. You can customize the tiles to be only the inputs you actually use, and for the wife it’s a lot easier to figure out what to get too haha
Lots of reading here, thread says the handler is withdrawn but resurrected or something…
Just a few questions to hopefully clarify. If I were to purchase a Marantz NR1607 receiver today, would I be able to use SmartThings to control it?
Would I be able to power it on/off?
Select/Change inputs?
Adjust volume?
Select speakers A/B/Both/Neither?
With exception of the speaker select, everything else you’d probaby be able to control using one of the handlers in this thread. I believe there is one specific to Marantz several posts aboce…if you cannot get it to work, someone on this thread will help, I am sure…
[quote=ā€œSBDOBRESCU, post:162, topic:36116, full:trueā€]
With exception of the speaker select, everything else you’d probaby be able to control using one of the handlers in this thread. I believe there is one specific to Marantz several posts aboce…if you cannot get it to work, someone on this thread will help, I am sure…[/quote]
Thanks… I already know the great folks in this place would assist.
Trying to decide whether to take this big step. I already have an older Denon receiver whose only flaw is that the remote has gotten a bit iffy… but there is no replacement remote available, and a good universal remote is expensive. So it’s likely either a new networked Denon or Marantz, or just live with the current scenario.
Not gonna rush it.
