Wired “enable/disable” switch for well pump
Switch is 240v capable. It cut the power to the pressure solenoid, low current.
Connections are to L1/L2 of contractor and disconnected the jumper from L1 to coil, connected white wire from switch. Coil is 240 volts.
Leak automation will turn off well now with leak detected in garage.
