Will 433mhz devices work
Will generic smart devices using 433mhz pair with Samsung SmartThings hub?
No the SmartThings hub doesn’t have a 433Mhz radio
Thanks, I was just looking at water leak sensors . I have one ordered for my sump pump but was looking for a small sensor for the floor at my basement door, which is a stairwell that has at least once leaked from a clogged drain.
It wasn’t a lot but enough that an early warning would have prevented a wet carpet.
Could you recommend one?
Any ZWave or Zigbee leak sensors should work fine. I use Dome’s leak sensors in my system because I needed ZWave ones.
