Here is the code I am using.
* Fan Control
* Copyright 2016 Glenn Brockett
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Things I want to do:
* Add option for using thermostat settings for setting and if in cooling mode.
* Optional Themostat device, if defined, will use both setpoint and if in cooling mode.
definition(
name: "Fan Control",
namespace: "ac7ss",
author: "Glenn Brockett",
description: "Turn on fan when outside temperature is lower than inside.",
category: "Green Living",
iconUrl: "https://iconalone.com/sites/default/files/styles/frontx48x48/public/Fan.svg_0.png",
iconX2Url: "http://downloadicons.net/sites/default/files/fan-icon-46129.png",
iconX3Url: "http://downloadicons.net/sites/default/files/fan-icon-46129.png",
oauth: true)
preferences {
section("Device(s) under control:") {
input "ThisSwitch","capability.switch", title: "Switched Device", required: true, multiple: true
section("Temperature sensors:") {
input "InsideTemp", "capability.temperatureMeasurement", title: "Inside Thermometer", required: true
input "OutsideTemp", "capability.temperatureMeasurement", title: "Outside Thermometer", required: true
section ("Temperature settings:") {
input "Delta", "number", title: "Temperature Delta", required: true
input "MinimumTemp", "number", title: "Inside Minimum Temp", required: true
input "MaxTemp", "number", title: "Always Run If Hotter Than", required: true
input "Override", "bool", default: true, title: "Override off time setting on always run setting?"
section ("Time Constraints") {
input "TimeOff","time", title: "Turn off at:", required: false
input "TimeOn","time", title: "Start program at:", required: true
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
state.fanRunning = false;
if ("on"==ThisSwitch.currentswitch){
state.fanRunning = true;
state.runtime = true
if (TimeOff) {
schedule(TimeOff, "stopCallback")
schedule(TimeOn, "startCallback")
subscribe(InsideTemp, "temperature", myHandler);
subscribe(OutsideTemp, "temperature", myHandler);
subscribe(ThisSwitch, "currentswitch", myHandler);
// TODO: implement event handlers
def stopCallback() {
state.runtime = false;
ThisSwitch.off();
def startCallback() {
state.runtime = true;
def myHandler(evt) {
def Inside=settings.InsideTemp.currentValue('temperature')
def Outside=settings.OutsideTemp.currentValue('temperature')
log.debug "Variables: $Inside $Outside $Delta $MinimumTemp $state.fanRunning"
if (state.runtime) {
if(Inside > MinimumTemp && ((Inside > (Outside+Delta))||(Inside > MaxTemp)) && !state.fanRunning ) {
log.debug "Turn on"
ThisSwitch.on();
state.fanRunning=true;
} else if ((Inside < MinimumTemp || (Inside < Outside && Inside < MaxTemp)) && state.fanRunning) {
log.debug "Turn off"
ThisSwitch.off();
}else if (!state.runtime) {
if(Inside > MaxTemp) {
log.debug "Offtime Turn on"
ThisSwitch.on();
}else if (Inside < MaxTemp){
log.debug "Offtime Turn off"
ThisSwitch.off();
