I have 2 automations set to run only when NIGHT MODE is active that are never firing.
First, I have an automation to turn on Night Mode at 9 pm every day, then another to turn Night Mode back off at 7 am every day.
I have 2 automations to send text messages for specific events only when Night Mode is active (using the “all conditions met” option). These are never firing. So it seems the first thing to check is whether Night Mode is actually the current mode.
Here are the 2 “night mode only” automations that are failing, followed by the automation that turns Night Mode on every day at 9 pm. Thanks for any suggestions.
In the app on your main screen (dashboard) click on More Options (the 3 dots in the upper right of the screen) and select Manage Location. Does your address appear in the geolocation section? If not, can you click on that and set your address.
Yes, I have quite a number of automations working successfully and bombarding me with texts, thank you. Only these 2 that are night-mode-only are failing to text me at night.
