I know its there
What are you implying?
Surely:
The firmware is cryptographically signed and cannot be modified in transit. If not, then Iām very very very concerned.
The Hub and SmartThings cloud can check the integrity of the Hub OS (including checking if Bluetooth or USB ports are enabled) and shut it down. If not, again, Iām very very very concerned.
He stabbed it with a stun baton, BAM active! (albeit briefly)
ST, are you listening to your user-development community??
couldnt you make bluetooth repeaters? At any event, it should be up to us, the customer, whether or not we want to use it.
No, and yes I agree.
Thereās something going on technically.
The wink hub has Bluetooth, but hasnāt enabled it for anything beyond the hubās own initial pairing.
The iris hub has Bluetooth, but hasnāt enabled it. ( they said theyāre waiting for Bluetooth mesh).
Google OnHub has Bluetooth, but hasnāt enabled it.
Vera Plus has Bluetooth, but it doesnāt appear to be functional beyond initial pairing.
Securifiās Almond 3 has Bluetooth, but hasnāt enabled it.
The SmartThings hub has Bluetooth, but hasnāt enabled it.
Seeing a pattern?
Since there are existing Bluetooth home automation devices on the market, notably some locks and buttons, the question is why havenāt any of these hubs enabled it?
I donāt know for sure, and I can think of at least two possibilities, but it does look like this is more than just a SmartThings issue.
Reading that article above gives me goosebumps :)) Bluetooth mesh network sounds amazing. Range would not be an issue in the perimeter of the home, power management in Bluetooth is outstanding, every command will be instant and setup from your already Bluetooth ready phone will be a breeze.
Just think of all the Bluetooth devices out there that are advertised as 1-2 year battery life !
How cool would it be to be able to buy those eBay Bluetooth color LED bulbs that come with a remote and cost $5 and have them connect to ST
Yeah, that would be cool. Unfortunately, itās not going to happen. The new Bluetooth canāt work with the old devices.
But it looks like the new Bluetooth will be in a number of mobile phones by the middle of 2017, and that should push the development of additional new devices.
Perhaps thereās a tech issue. I donāt know.
What I DO know is this: phones as presence devices would be a heckuva lot easier if BT were enabled at the hub. Make the hub always discoverable but not pair-able without a valid code, put BT Autoconnect on your android phone, and away you go.
Target has introduced a series of la is that have Bluetooth integration.
They looks pretty sweet and cost about the same as a non-smart lamp. Iād love to hear that they would work with my ST!!
Hi
Iāve been foolowing the topic for BT news with ST. Any one knows anything?
I intend to integrate a BT Soundbar.
When (and if) SmartThings enables Bluetooth, I doubt itāll support audio. AFAIK, it only supports BLE (GATT profiles).
I would love BT so that my Anymote could be natively integrated with my Smarthing Hub!
Thanks for the comments
As @geko mentioned, itās unlikely that smartthings will ever use the Bluetooth profile that the Soundbar uses.
If the Soundbar is compatible with the $89 harmony hub, you could get integration that way.
Iām getting ready to give up on St ecosystem. Itās all a bunch of false promises and end of life on products they sell⦠No bt, no thingshield and todayās update messed my ZigBee up completelyā¦
Since the last update the hub IDE has no listing for BT at all.
Any update Smartthings???
