What's a cheap zigbee repeater?
Yes, works great for me. No more bad coverage
Don’t forget the point you can actually use it as a relay if you want to!
I’m confused about the Orvibo thing - does it plug in? It doesn’t look like it has a plug…
It has no plug but takes a mains input.
You can wire it with a plug or via a junction box or whatever, it just needs a supply.
Anyone seen this in stock anywhere? Been checking banggood but it never comes into stock:
ORVIBO ZigBee Smart Home System Multi-functional Household Appliances Remote Control Relay
This is the relay similar to the Wemo Maker I believe. Would prefer to get one of these instead of the RGB Relay.
Only place I found it so far is on Amazon but it’s too expensive.
ikea tradfri bulbs linked directly to the smartthings hub seem to be reliable… time will tell. I will report back in a week.
If good, these will prove super cheap.
Any luck with the Ikea Tradfri bulbs?
yes and no. If you leave them alone, they seem ok. As soon as the wife, or visitors mess with the switch, then havoc ensues.
I have taken them out the mesh for that reason (i moved them to my hue)
I recently purchased a Peanut Plug for $20 on Amazon to use as a Zigbee repeater for my fan controllers with very poor Zigbee antennas and it works great. Might be worth a shot at that price.
This is what I got. So far it is working great. I was having connectivity issues with two contact sensors upstairs and one on my shed outside. Plugged this into my master bathroom and plugged a space heater in so now bathroom is warm when my wife gets home from morning run and connectivity issues are resolved. $24
SYLVANIA SMART+ ZigBee Indoor Smart Plug, Works with SmartThings and Amazon Echo Plus, Hub Needed for Amazon Alexa and Google Assistant https://www.amazon.com/dp/B01M6UM8QD/ref=cm_sw_r_cp_tai_bSYFAbY1J0PC2
Hi, been reading this thread with interest. I’ve recently switched all my Hive zigbee devices over to Smartthings except the Hive signal booster but now I’ve found that the farthest Hive sensor no longer reports activity. Can I simply use the Hive signal booster to boost the zigbee signal once paired with Smartthings ?. Thanks.
I got one of those Iris Smart Plugs because I had some unreliable smart bulbs (Cree, Sengled and IKEA) that were a floor away from the hub. Man, it worked like a charm! Now no misfires on any of those problem bulbs. It also serves as a ZWave repeater too, but I wasn’t having any issues with those devices anyway. Anyway, the Iris plug is highly recommended.
Hi, just trying to be clear on all this, still new to it all. So i have everything set up on my ST hub all work perfect now I went to install some motion sensors and door sensors (ZigBee’s) in the garage to find out it is just out of signal reach for the hub. I have been reading a lot of the posts and seems if I purchase say a GE zigbee pocket plug it should work as a repeater? do I just have to plug this in the garage and it will boast the single? not really clear on where this plug needs to be in order to work. or is there a better way?
It doesn’t boost the signal the way a Wi-Fi booster does. It’s just that in a mesh network like the zigbee home automation that smartthings uses, one device can pass along a message meant for another device.
Think of it like the old pony express. The first horse rides as far as it can, say 20 miles. Then it stops at a way station and the rider gives the mail pouch to the next rider, who takes a different horse And they ride the next 20 miles to the second waystation. Where again the mail pouch is given to a new rider Who goes the next 20 miles.
It’s the same way with Zigbee messages. If each device can send a message about 40 feet and you need to cover a distance of 55 feet, if you put a device that is capable of repeating about 30 feet from the hub then the message will get sent to the first device (30 feet) who can then transmit it on to the second device which is another 25 feet away.
Most mains powered zigbee devices will repeat except for Sengled lightbulbs. Most battery powered devices will not.
So in your case, position the GE pocket socket so that it can successfully transmit to both the hub and to the garage sensor. Then it will pass messages between them.
So you aren’t boosting the signal, you’re just adding another rider to the process. You’ll likely place it about 3 m in from the edge of the range from the hub. That way it will have a strong signal to the hub but it will be able to carry-on for another 20 to 30 feet past your previous range limit.
For more information, see the following FAQ. Start with post 11, read that, then go up to the top of the thread and read the whole thing.
Ah OK thank you for the clear explanation i understand now. So I guess my question now is what are most doing and what is the best solution to date. Can i add one of the connect home unit to my smarthings hub? i do have wired network in the garage.are they compatible? I would like to keep everything on the same app.
Thanks Again
Louy
It broke my heart and my pocket book took a hit, but I just bought some additional SmartPlugs from Smartthings when they were on sale. I have plugged them in at key locations to pick up the ST Presence Senors that we use in our home. Nothing is plugged into the Sm.Plugs at this point, they are just relay points.
There really aren’t any Zigbee repeaters. Everyone expects the lights/switches to do that job.
I did also add a Zwave repeater to help with pushing the signal outdoors for the Christmas display. That seems to work OK.
Thank you i did the same there on there way. there are these but i don’t know if they will work? if there is anyone that knows please let me know. https://www.digikey.ca/scripts/DkSearch/dksus.dll?Detail&itemSeq=254404063&uq=636564676645604241
Louy
Hi, I had the same issue with my garage door sensors… the signal would not reach it. So first I put a smartthings power plug in the shed which is next Door to the garage but still no signal. I then looked up some article about the antenna positions of the ST hub…it works out that if you hold the hub flat against the wall and wires hanging down…the top side has the strongest signal for zwave and the right side has strongest zigbee signal. As soon as I pointed the zigbee right side towards my garage, the power outlet got signal and that repeated it on to my garage door sensor, tradfri bulb and the car presence sensor…problem solved :slight_smile:
This is the article…picture is further down it:
Not being grumpy! You said exactly how I’m feeling, but just apparently too lazy to write it. Thanks for sharing.
This is an interesting article.
The picture is of the V1. Does anyone know if the position of the V2 antennas are the same?
