What other uses for a Tilt Sensor other than the obivious?
I have a ST multisensor that has three-axis sensing. Tried to use it on a motorized skylight, but that skylight apparently moves too slowly to register on the sensor. Ahhh well…
I have decided, I am going to try a few of the suggestions, and use the one I think I will get the most use out of. And I might use one I called obvious.
Robin, lets not go there. My wife alter ego is Attila the Hun.
Place one in the recliner back and it will let you know when gramps is taking it easy. Also it will let you know if he’s been reclining for more than 30 minutes so you can go wake him up lol
This is a smart home forum. We don’t go to wake someone up, we have an automation that activates a siren.
@joelw135
On your washing machine door to get notified if your finished laundry hasnt picked up for hours and hours. maybe too #obvious.
On the underside of the dedicated wife-sofaseat.
To start the heating blanket (via smart outlet) within the sofa cushion if someone=wife sits down and seperates both parts. the second part is taped
to not be too “sticky”!
if room temperatur is below 19 degres (Celcius) and if presence is detected at the room “sofa” and if not no-one is at home and if holiday and/or night switch is not “on” #experimental #onyourownrisk #doesnotworkeverytime
