Wemo Insight modification needed
(Matthias Ertl) #1
Hi,
im Using WeMo DTH from Author: Jeroen Keppens, 14/3/2016 for my insight switch.
since im using my wemo insight switch to chech the washer i want to do a modification:
on my things list, its always showing the “switch” state of the insight (ON or OFF) - when i click it, it toggles the status.
Now i want to have, that its showing the “status” state (off, active or standby) - when i click it, nothing should happen.
can i edit this in the DTH ?
*  Copyright 2015 SmartThings
*  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *	Wemo Switch
 *	Author: superuser
 *	Date: 2013-10-11
 *  Updated for Wemo Insight Switch
 *  Author: Jeroen Keppens, 14/3/2016
 metadata {
	definition (name: "Wemo Switch2", namespace: "smartthings", author: "SmartThings") {
		capability "Actuator"
		capability "Switch"
		capability "Polling"
        capability "Power Meter"
		capability "Refresh"
		capability "Sensor"
        attribute "status", "string"
        attribute "onNow", "string"
        attribute "onToday", "string"
		command "subscribe"
		command "resubscribe"
		command "unsubscribe"
	// simulator metadata
	simulator {}
	// UI tile definitions
	tiles {
		standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
			state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821"
			state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff"
        valueTile("power", "device.power", decoration: "flat", width: 1, height: 1) {
        	state "power", label:'${currentValue} W'
        standardTile("status", "device.status", width: 1, height: 1 ) {
			state( "on", label: 'An', backgroundColor: "#79b821" )
			state( "standby", label: 'STANDBY', backgroundColor: "#FFA500" )
			state( "off", label: 'Aus', backgroundColor: "#ffffff" )
        valueTile("onNow", "device.onNow", decoration: "flat", width: 1, height: 1) {
        	state "onNow", label:'${currentValue}'
        valueTile("onToday", "device.onToday", decoration: "flat", width: 1, height: 1) {
        	state "onToday", label:'${currentValue}'
		standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 1, height: 1) {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
		main "switch"
		details (["switch", "power", "status", "onNow", "onToday", "refresh"])
private def parseBinaryStateString(stateString) {
	//log.debug "stateString: $stateString"
    //log.debug "stateString.size(): ${stateString.size()}"
	def states = []
    def token = ""
    for(int i=0; i<stateString.size(); i++) {
    	if (stateString[i] ==~ /[0-9]/) {
        	//log.debug "symbol: ${stateString[i]}"
        	token = token + stateString[i]
        } else {
        	//log.debug "adding token: $token"
            int state = token.toLong()
            states << state
            token = ""
    //log.debug "states: $states"
    return states
private def convertSecondsToTimeString(seconds) {
	log.debug "convertSecondsToTimeString of $seconds seconds"
	int h = seconds.intdiv(3600)
    int m = (seconds-h*3600).intdiv(60)
    int s = seconds-(h*3600)-(m*60)
    log.debug "h: $h, m: $m, s: $s"
    def timeString = ""
    if (h==0) {
    	timeString = timeString + "00"
    } else if (h<=9) {
    	timeString = timeString + "0$h"
    } else {
    	timeString = timeString + "$h"
    if (m==0) {
    	timeString = timeString + ":00"
    } else if (m<=9) {
    	timeString = timeString + ":0$m"
    } else {
    	timeString = timeString + ":$m"
    if (s==0) {
    } else if (s<=9) {
    	timeString = timeString + ":0$s"
    } else {
    	timeString = timeString + ":$s"
    return timeString
	log.debug "Parsing '${description}'"
	def msg = parseLanMessage(description)
	def headerString = msg.header
	if (headerString?.contains("SID: uuid:")) {
		def sid = (headerString =~ /SID: uuid:.*/) ? ( headerString =~ /SID: uuid:.*/)[0] : "0"
		sid -= "SID: uuid:".trim()
		updateDataValue("subscriptionId", sid)
	def result = []
	def bodyString = msg.body
	if (bodyString) {
		def body = new XmlSlurper().parseText(bodyString)
        //log.info "Line 67 bodyString: $bodyString"
        //log.info "Line 68 body: $body"
		if (body?.property?.TimeSyncRequest?.text()) {
			log.trace "Got TimeSyncRequest"
			result << timeSyncResponse()
		} else if (body?.Body?.SetBinaryStateResponse?.BinaryState?.text()) {
			log.trace "Got SetBinaryStateResponse = ${body?.Body?.SetBinaryStateResponse?.BinaryState?.text()}"
		} else if (body?.property?.BinaryState?.text()) {
        // To Do: Refactor
            def wemoStateString = body?.property?.BinaryState?.text()
            log.info "State string: $wemoStateString"
            def states = parseBinaryStateString(wemoStateString)
            def value = states[0] == 0 ? "off" : "on"
            log.trace "Notify: BinaryState = ${value}"
            result << createEvent(name: "switch", value: value)
            if (states[0]==0) {
            	result << createEvent(name: "status", value: "off")
            } else if (states[0]==1) {
            	result << createEvent(name: "status", value: "on")
            } else {
            	result << createEvent(name: "status", value: "standby")
            if (states[2] != null) {
            	log.debug "states[2]: ${states[2]}"
                def onNow = convertSecondsToTimeString(states[2])
                log.trace "Notify: Time on now = ${onNow}"
                result << createEvent(name: "onNow", value: "on now  $onNow")
            if (states[3] != null) {
            	log.debug "states[3]: ${states[3]}"
                def onToday = convertSecondsToTimeString(states[3])
                log.trace "Notify: Time on today = ${onToday}"
                result << createEvent(name: "onToday", value: "on today $onToday")
            if (states[7] != null) {
            	log.debug "states[7]: ${states[7]}"
            	def power = (int)Math.round(states[7]/1000)
            	log.trace "Notify: Current power consumption = ${power}"
            	result << createEvent(name: "power", value: power)
			//def value = body?.property?.BinaryState?.text().toInteger() == 1 ? "on" : "off"
			//log.trace "Notify: BinaryState = ${value}"
		} else if (body?.property?.TimeZoneNotification?.text()) {
			log.debug "Notify: TimeZoneNotification = ${body?.property?.TimeZoneNotification?.text()}"
		} else if (body?.Body?.GetBinaryStateResponse?.BinaryState?.text()) {
        	// To Do: Revise
			def wemoStateString = body?.Body?.GetBinaryStateResponse?.BinaryState?.text()
            log.info "Binary State Response (not processed at this point): $wemoStateString"
	result
private getTime() {
	// This is essentially System.currentTimeMillis()/1000, but System is disallowed by the sandbox.
	((new GregorianCalendar().time.time / 1000l).toInteger()).toString()
private getCallBackAddress() {
	device.hub.getDataValue("localIP") + ":" + device.hub.getDataValue("localSrvPortTCP")
private Integer convertHexToInt(hex) {
	Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
	[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
private getHostAddress() {
	def ip = getDataValue("ip")
	def port = getDataValue("port")
	if (!ip || !port) {
		def parts = device.deviceNetworkId.split(":")
		if (parts.length == 2) {
			ip = parts[0]
			port = parts[1]
		} else {
			log.warn "Can't figure out ip and port for device: ${device.id}"
	log.debug "Using ip: ${ip} and port: ${port} for device: ${device.id}"
	return convertHexToIP(ip) + ":" + convertHexToInt(port)
def on() {
	log.debug "Executing 'on'"
    sendEvent(name: "switch", value: "on")
def turnOn = new physicalgraph.device.HubAction("""POST /upnp/control/basicevent1 HTTP/1.1
SOAPAction: "urn:Belkin:service:basicevent:1#SetBinaryState"
Host: ${getHostAddress()}
Content-Type: text/xml
Content-Length: 333
<?xml version="1.0"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<SOAP-ENV:Body>
	<m:SetBinaryState xmlns:m="urn:Belkin:service:basicevent:1">
<BinaryState>1</BinaryState>
	</m:SetBinaryState>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>""", physicalgraph.device.Protocol.LAN)
def off() {
	log.debug "Executing 'off'"
	sendEvent(name: "switch", value: "off")
	def turnOff = new physicalgraph.device.HubAction("""POST /upnp/control/basicevent1 HTTP/1.1
Content-Length: 333
<SOAP-ENV:Body>
<BinaryState>0</BinaryState>
	</m:SetBinaryState>
</SOAP-ENV:Body>
/*def refresh() {
	log.debug "Executing 'refresh'"
SOAPACTION: "urn:Belkin:service:basicevent:1#GetBinaryState"
Content-Length: 277
Content-Type: text/xml; charset="utf-8"
HOST: ${getHostAddress()}
User-Agent: CyberGarage-HTTP/1.0
<?xml version="1.0" encoding="utf-8"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1">
</u:GetBinaryState>
</s:Body>
</s:Envelope>""", physicalgraph.device.Protocol.LAN)
def refresh() {
	log.debug "Executing WeMo Switch 'subscribe', then 'timeSyncResponse', then 'poll'"
	[subscribe(), timeSyncResponse(), poll()]
def subscribe(hostAddress) {
log.debug "Executing 'subscribe()'"
def address = getCallBackAddress()
new physicalgraph.device.HubAction("""SUBSCRIBE /upnp/event/basicevent1 HTTP/1.1
HOST: ${hostAddress}
CALLBACK: <http://${address}/>
NT: upnp:event
TIMEOUT: Second-5400
def subscribe() {
	subscribe(getHostAddress())
def subscribe(ip, port) {
	def existingIp = getDataValue("ip")
	def existingPort = getDataValue("port")
	if (ip && ip != existingIp) {
		log.debug "Updating ip from $existingIp to $ip"
		updateDataValue("ip", ip)
	if (port && port != existingPort) {
		log.debug "Updating port from $existingPort to $port"
		updateDataValue("port", port)
	subscribe("${ip}:${port}")
def resubscribe() {
log.debug "Executing 'resubscribe()'"
def sid = getDeviceDataByName("subscriptionId")
SID: uuid:${sid}
def unsubscribe() {
new physicalgraph.device.HubAction("""UNSUBSCRIBE publisher path HTTP/1.1
SID: uuid:${sid}
//TODO: Use UTC Timezone
def timeSyncResponse() {
log.debug "Executing 'timeSyncResponse()'"
new physicalgraph.device.HubAction("""POST /upnp/control/timesync1 HTTP/1.1
SOAPACTION: "urn:Belkin:service:timesync:1#TimeSync"
Content-Length: 376
 <s:Body>
  <u:TimeSync xmlns:u="urn:Belkin:service:timesync:1">
   <UTC>${getTime()}</UTC>
   <TimeZone>-05.00</TimeZone>
   <dst>1</dst>
   <DstSupported>1</DstSupported>
  </u:TimeSync>
 </s:Body>
</s:Envelope>
def poll() {
log.debug "Executing 'poll'"
Content-Length: 277
<s:Body>
</u:GetBinaryState>
</s:Body>
thanks a lot,
Matthias
Multiple hubaction commands in one function and parsing the response
