WeMo in wall switch with two wires
Hello, I installed 4 WeMo switches yesterday but one of my old switches only had 2 wires plus the ground. I found online a solution that somebody else used and it worked for me too.
First black to the black wire from the wall, second black with the white wire from the wall and the green and white from WeMo, to the ground in the wall.
It works well with led dimmable bulb or with the old spiral economical bulbs.
I am still testing it and checking if it gets hot or there are any weird signs. Everything looks great after 24 hours, there is no flicker.
Please let me know if I should expect any issues from this setup.
I’m not an electrician but I’ve read enough to know that this is a bad idea. Perhaps someone more knowledgeable like @Navat604 can explain why exactly this is dangerous and you may be putting yourself (or your family) at risk.
On the WeMo forum it says that when the green and the white are connected to the ground, if the switch fails, the fuse will pop.
I think that you are right Mark, I will have to get one of those inline micro-switches that go directly in the light fixture box. I checked and I have a neutral there. Unfortunately the wire was not passed to the switch box. I can not understand why electricians do that.
Here is a good post on this forum about exchanging ground and neutral wire. It’s not safe to do so.
As for why electricians don’t bring neutral to the switch box. Well, it was not a requirement just like wire colors and sometime that’s the most feasible and cheapest way. Also there is no such thing as smart switch that required neutral back then. You can thank the many standards between not just states but cities as well.
I know it’s too late but do check your wiring first before the purchase. Hopefully you can still return the Wemo switch or use it somewhere else.
Sorry JD. I didn’t see your post :grin:
We crossposted. But yours was better than mine so I deleted mine. :wink:
Thank you guys, I already took the switch out. I will use it some place else. It looks like only my hallway switches are missing the neutral.
It is a 2005 apartment building and all the other switches have the neutral, that’s why I do not understand why these two hallway lights don’t.
Last two they wired and got lazy lol
That’s another good option, just more effort to install than a wall switch. I live in an old apartment building and my unit was probably last renovated around 2000-2001, so no neutrals in the switch boxes. Much more complicated to find a good connected lighting solution. I did wire one three-way light with an aeon micro switch up in the fixture box. It was a tight fit in the fixture box but it works great for automations and I can still use both of the dumb switches on the circuit. I’m hoping aeon will finally release their nano switch and then I might install in a few more fixtures.
Glad to hear you decided against using the Wemo switch in this potentially unsafe manner.
Are they going to be released this year?
Maybe? Aeon has a really bad habit of listing some upcoming devices on their website for–no joke–years before they actually get released. They even had a smart window film product on there for maybe two years that they eventually announced they couldn’t bring to market. That was a huge bummer.
Do you think that a micro switch will fit in this box?
I have my finger on the Order Now button, I do not think that I will wait for the nano version :slight_smile:
Should fit I think. Mine was an especially tight fit because I had other wire bundles in that fixture box. If aeon hasn’t actually announced a release date yet (they didn’t last time I checked) then I’d prob just buy a micro switch if I were you.
Alternatively, enerwave has newer generation in-wall (or in-ceiling) relays that are smaller, I think.
I agree. The Enerwave is also z-wave plus and smaller but the Aeon micro g2 has enery monitor so it’s all depend on your need.
Do enerwave have a dimmer version?
Could you please provide a model number?
As far as dimmer. I think only Aeon and Fibaro make dimmers. Here is a link for the Enerwave.
https://www.amazon.com/gp/aw/d/B01G7OD3ME/ref=mp_s_a_1_1?ie=UTF8&qid=1476675820&sr=8-1&pi=AC_SX236_SY340_FMwebp_QL65&keywords=enerwave+z-wave
Thank you for the link, I think that I will go with Aeon Labs.
Looking at my picture posted above, should I use the wires on the left and on the right? There is no ground on the micro switch from what I see on their site
Not really sure what you question is but the romex with the white wire to your bulb is your power from the circuit breaker and the romex with the black wire to your light bulb is from the light switch. You will need both connecting to the Aeon micro controller. You are right about ground wire. The Aeon doesn’t have one.
I know that it does not respect the drawing standards but I was thinking of something like this:
(double line=white wire;single line=black wire)
Thanks again for the patience in answering my questions
The drawing looks correct. Have fun and don’t forget to turn off power first. No problem at all. Glad I could help.
