I recently purchased a GE Smart Switch to control my exterior house lights. I installed the box and I have the two standards black wires and the copper ground wire but no neutral line.
I connected the black wires like normal and put the copper on the green ground and nothing worked. I then connected the copper to the neutral and everything works just fine.
My question is, although it works is this bad? I assume the device requires a neutral which is not currently present.
How can you have just 2 black wires and a ground? Are you sure there are no other wires in the switch box? A normal “2 wire” run will have a black, white and ground.
I replaced normal switches in a 4 switch box. I put in the GE smart switch and three regular rocker switches.
The regular switches I replaces had the two black wires on the right and a ground bare copper on the left and thats it. I replaced the three regular switches just fine. I am assuming they never required neutral wires.
There might be a possibility that there is a neutral line back there and capped off but I initially didn’t see one. The house was built in 2008 so it should.
In most installations your white neutrals will be capped off and crammed in the back of the box. So follow your wires from the switch terminals back to their cable and see if the cable has a white wire. If your house was built in 2008, I can’t imagine you not having neutrals…
