Does anybody know if there is a way, through SmartThings, to determine if a device has beaming capabilities?
While searching the web I found this information but it seems to apply only to Vera and how it identifies the devices that connect to it.
If it’s a certified device, you can check the zwave alliance “implementation conformance statement.” I believe all the GE hard wired switches and plug in receptacles that are zwave do now support beaming (secure Communucation). I know the dimmer outlet 12718 does, it’s the one I’m using as a repeater to my zwave door lock.
Thanks JDRoberts,
I should have asked this question earlier it would have saved me countless hours trying to find something on the internet that confirmed that the wall switches I have actually support Beaming functionality.
My recent bad experience with one of my locks forced me to do research on which of my outlets support the beam command. It turned out that the closest outlet does. I am using Leviton DZPA1
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=DZPA1-1LW§ion=66154
@SBDOBRESCU I too got here since I got annoyed enough with my lock to start digging. I believe I saw you all over the kwikset lock issues in regards to batter reporting. I was wondering what did you eventually end up doing. I just sent kwikset an email discussing that perhaps my unit is defective. While that convo is in progress I also took a look at this repeater business. I am looking at Leviton DZPA1-2BW since it has beaming but was wondering if that did the trick for you or did you end up cutting bait and buying a different lock. I have the kwikset 916 and the v2 hub.
